Drag0n
- Jun 11, 2004
Thanks...
What i may do is use the V2^2 Maxxed on the Elpac with my pc and Grado SR80 , and the V2 2005 vintage for portable,cuz the battery life is much better, and ill try those batteries also for more life.
The V2 seems to work with any 9v i stick in it, and the maxxed totally needs really good batteries or it whistles like it does when the battery dies,so it shows how much the thing draws. I did a comparo between them tonight,and the maxxed is a bit better....but not crazy better for my portable setup, so the standard v2 is fine with my Zune and Igrados.
I heard Romanee's V2 against a Hornet and Tomahawk at the NY meet,just before Head-Fi fell in November, and it was noisy and hard to compare....but from what i can hear, it was in the same league in sound i would think.
Id love to do a much better listen with my own headphones and in a quiet location sometime, against some top portables.
I went looking for a 12v battery pack with a plug on it to carry when i want to use the maxxed as a portable, but i havent found what i want yet.
As i said,the battery is a pita to change in the maxxed, but awesome in the V2.....so maybe ill open the maxxed and think of a way to improve it,if possible. Maybe a better wire and plug or some kind of thing.
Originally Posted by tnmike1 /img/forum/go_quote.gif First, I'll address your battery issue. Go to Thomas distributing and get the 9.6v PowerX--if I have the name wrong, it's a white battery with black and blue lettering. Should be on the first page of the 9v NiMH page. Fits very well with room to spare in my Portaphile PLUS lasts about 10 hrs. Second--my Portaphile just came back from Cesar with a switch problem and I asked--because somewhere someone else asked--if I REALLY needed all switches "on" for maximum sonic quality. asked this because I'm running a 5.5g Imod with ALO cryo cables so wanted best sound possible out of the amp. He said if I had the latest version--which I do--then the "wide bandwidth" option could be switched to "off" and that the wide bandwidth option was better used in the older maxxed Portaphiles. So if you have a recent, or latest, version, would suggest you switch it to "off" and will get better battery life. If the battery is whistling, it means it's about dead, so probably wold not be worth putting it in the Portaphile. But yeah, you me and Romanee--and I suppose some others--praise the quality of this little amp. Too bad, asyou say, battery life is so low, but Cesar helped in his suggestions on how to stretch it a bit. O forgot to mention: those batteries are 300 mah and 275 mah so you should be getting longer life between charges than the one you're using |
Thanks...
