Portable Tube amp by Oatley: K272
Mar 15, 2010 at 8:27 PM Post #16 of 33
Originally Posted by netsky3 /img/forum/go_quote.gif
I've bought this amp few days ago. Anyone use the amp with a power supply?
I have here one at 12V and 1000mah, is too much?
A 12 volt supply is no problem. I've read people going to 18 volts. Note: 30 volts is the maximum plate voltage of these tubes. The L4949 can handle max. 28 volts. I have one too, still unboxed, getting its juice from a adjustable PSU currently @ 15 volts.
A 1000mA supply shouldn't even break a sweat.
There's a lot of info here: Vacuum Tubes / Valves • DIY Audio Projects Forum You can find pics of mine too.
Mar 16, 2010 at 12:36 AM Post #17 of 33
many many thanks dude!!
Mar 21, 2010 at 12:28 AM Post #22 of 33
Mar 29, 2010 at 6:31 PM Post #24 of 33
Which version of the board? The newer version has two AA size batteries in a clip mounted on the PCB and needs a 9 volt battery. I have the old version that runs on a single 9 volt battery. The old version measures 44 x 104.5mm.
Mar 29, 2010 at 7:30 PM Post #25 of 33
I should receive the newer version, with the clip on the pcb. Same dimension i think.
Thanks anyway
May 19, 2010 at 12:46 AM Post #28 of 33
I had just ordered one of this amp. Anyone has the dimensions of the board for the newer version amp? Need to hunt for the case for it.
Wondering how long it take to arrive, really looking forward to receive it. Thanks.
