flippant1
- Jul 18, 2015
Hello,
I am looking for a DAC/AMP of my iPhone 7 to use directly with my Shure 1540 and Shure 535 headphones.
I am had tested a Fifo Q1 and A3 and am now interested in the Fii0 17K and Dragonfly Black with Apple USB to lightning cable. I really want the utility/soiund of a DAC. I did not hear any significant difference and understand that it passed through if plugged directly form an iPhone and not a USB source.
Can someone straighten me out on my options. I have scoured the net but am still confused on using a device like the 17K with the iPhone, my primary source.
If the amplifier is plugged directly through the line input on either unit, will the DAC be disabled?
If so is there any work around perhaps using the Apple USB to lightning converter cable?
Can either of the units be used as a portable DAC directly with an iPhone 7?
Any recommendations in the price range or a bit higher. I hesitate with the Dragonfly as there is no eq. or tone control, and would prefer a separate power source not to drain my already underpowered phone/player.
Thanks for you input.
Respectfully submitted.
