drew911d
I recently got balanced cables and I had that "what is what" idea. Basically, I though what is the difference from? Cable material (silver Litz), diameter (more current capacity) or the balance mode? Well, I think now it's a bit of each. First, I think the diameter is the main difference. I've been an electronics tech for 30 plus years and I know wire diameter has a great deal to do with current flow, resistance and such.. really can affect sound reproduction in low impedance circuits. IEM is that circuit, typically.
Anyway, I really noticed a difference with my K10's. The extra current had a lot to do with it. I have an adapter that let's me use my silver litz cables in stereo mode, so I can say that the cable material and gauge does make an improvement, probably equal to the balanced mode because even in stereo mode there is a great improvement over the already great OEM cables Noble uses (SPC of a smaller guage, but more flexible). However, I can see that it takes high end HP or IEM to get that extra benefit of the balanced mode. When I use balanced mode vs stereo silver litz the difference is slightly less than going with the silver litz greater diameter cable. So, that means the greater gain in my perspective is with better wire material/diameter. However, the balanced mode really adds to it in an extra perceptive with high end HP or IEM. You have to look for it with lesser HP/IEM, but it is really there if your phones can deliver. The sum is greater than the parts, in this case. Great IEM/HP will be great return.
The flexibility of a cable has a lot do with AWG. The bigger the cable, the less flexible. Material can make a difference, but bulk is bulk. I'd rather appreciate the extra current capacity for the bulk. See any high end after market cable and you'd see that there is a trade off, one most of who's buy an after market cable will accept. For what? I guess there has to be a reason. Most after market cables are rather bulky, with few exceptions. Hell, I considered an 8 wire, Silver/Copper hybrid. That's some bulk, indeed! The sound quality is up for you to decide.
