jackson1
- Oct 3, 2012
Hi guys,
I just found some old headphones that I forgot I had. I bought them back in the early 1990's I think. I hope you can help me identify them and share some specs on them.
As you can see from the pictures, they are named "PMB 65". Is PMB simply the manufactor? I seem to remember these were AKG's or maybe even Peerless, but I'm not sure at all. Please tell me what you know about these. Apparently they are German made.
Beware the pictures. I had to replace the earpads + inner foam because they were totally deteriorating. So I took the pads and foam from my DT 770's, which fits nicely after sanding the diameter of the PMB 65's a bit down. I'm ordering new pads and foam for my DT 770's of course.
Soundwise, compared to my DT 770's, the PBM 65's lack deep bottom end, but apart from that, they sound pretty open and clear, especially in the upper mids, which makes them usable in my studio work, recording and mixing music.
Since the "Insert image" function here results in an error ("There was a problem submitting this to the server. Please try again."), here are a few links to pictures:
http://i13.photobucket.com/albums/a294/hjorte/pmb-65-01_zps3efff1bf.jpg
http://i13.photobucket.com/albums/a294/hjorte/pmb-65-02_zps00b22f2f.jpg
http://i13.photobucket.com/albums/a294/hjorte/pmb-65-04_zpsef72e3f2.jpg
http://i13.photobucket.com/albums/a294/hjorte/pmb-65-03_zpsb7e4047a.jpg
http://i13.photobucket.com/albums/a294/hjorte/pmb-65-10_zps4c0323f9.jpg
