Vinman
- Nov 11, 2004
Ok, I am trying to cannabalize a set of buds from my iPhone and "merge" them with my Sony MDR-EX90s. Ideally, I want to be able to use my mic/iPod switch with the much better EX90 buds.
Started the project simply enough -
I removed the right bud from the iPhone cord. There are three sets of stranded wires - 1 gold, 1 red, 1 red/green twisted pair.
I then pulled back the rubber sheathing at the plug end of the Sony cord and found three stranded wires. 1 gold, 1 red, and 1 green.
I haven't removed the buds from the Sony cord yet, because the wiring wasn't quite as obvious as I'd expected, and I don't want to ruin the Sonys trying to do something that I'm not particulary adept at, anyway.
My question is this...
Should I expect to find the same 1 gold, 1 red, and 1 red/green twisted pair at the right bud end of the Sonys? I don't want to damage the plug end of the iPhone cord because it needs to remain intact. The extra wiring associated with the mic and switch are only going to confuse things, anyway.
The other confusing thing is this...
When I used my continuity tester on the iPhone cord, not one of the three wires showed flow back on the plug. On the Sony cord, after pulling back the sheath at the plug, I got flow on the gold wire across the entire plug, but none for the red or green wires. I guess this is more theoretical than functional knowledge, but it's still a little puzzling. While we're at it, I was a little puzzled by the fact that there are three sets of stranded uninsulated wires carrying the signals to the right bud (only two to the left). Why don't they short - or at least mix the signal and screw up the polarity??
Assuming I pull the Sonys apart and find the same sort of configuration, should I solder all three sets as one joint (since they are all uninsulated together), or should I make seperate solder joints for each stranded wire?
I plan to finish off the project by soldering the proper sets of wires, using liquid tape, then heat shrink tubing. Is this the strongest method of finishing?
I'm hoping that I'm just overcomplicating an easy job, but I don't want to continue until I get some confirmation that the Sonys should be wired the same, and all I have to do is splice, solder, and seal.
THANKS!
THANKS!
![etysmile.gif](http://images/smilies/http://hfimage.head-fi.org/smilies/newsmiles/etysmile.gif)
