fuzzyash
- Apr 25, 2012
smallest music collection here?
i got just under 5 gigs of mp3/alac/flac...
I honestly couldn't tell you. It could be jitter? If you look on the Jplay forums you'll find people going to much further lengths than I would ever dream of. USB cards, cables, special SSDs, dual computer setups. Even many who insist that SSDs are no good either who use some other kind of flash storage with a converter. And the tweaks they do software wise are immense. I won't lie, if I cut down a lot of background services there is a tiny difference, but I'm not willing to brick my computer for everything but audio use as many of them have.
No media player has direct hardware access. All hardware calls are still handled by the OS.
I understand that jplay in combination with windows server 2012 rc2 in core operation does help..as it uses DOS screens again
I'm not a big fan of SSD, frankly. I know the advantages they're supposed to have over conventional disks but I had the singular bad luck of experiencing 2 SSD failures on a Macbook that I upgraded to use with SSD (2 years back, purchased a new one since). To be honest, I think it must have been some hardware incompatibility although Apple never offered an explanation for it. It was extremely fast...while it lasted. But if/when they fail, they fail without warning and catastrophically. I learned the hard way to always have a bootable conventional harddisk with me at the time. Became a royal pain very quickly (nothing worse than a system that you know is not totally reliable). Back to conventional disks and this drobo 'beyond raid' storage now.
I use ZERO bytes for music storage. I use vintage discmans and CDs to play music. Now how will you and your survey account for people like me ?
There have been some compatibility issues, as well as needing third party utilities to enable TRIM support (without this, wear will happen more quickly)... And when SSDs fail, they fail pretty good, that's for sure. But assuming you don't face compatibility issues, they should be much more reliable - HDDs are just failures waiting to happen, I've always hated the things. Anyway, sorry to hear about your experience... no matter what the tech, main takeaway from all of this is to always have a backup.
....the chances of 2 or more hard drives failing at the same time is almost zero....
Not if they are identical drives with identical usage, such as drives from the same manufacturing batch used in a mirrored RAID (same controller, same loads, same temperatures, same lifespan). You then have extremely unwelcome and enhanced odds of them failing very closely together. That's one of the reasons why mirrored RAID is no substitute for back up.
HDD's are extremely reliable when used redundantly. A single hard drive is likely to fail at some point but 2 or more HDD's in a NAS device is a very reliable method of storage because the chances of 2 or more hard drives failing at the same time is almost zero. As I mentioned in my post above, I use a redundant NAS device and then backup its contents to a separate external drive as well, in case the NAS itself fails. The only way to get better redundancy than that is to also backup the data remotely (off-site) but that can be pretty costly when you're dealing with large amounts of data.
