saint.panda
Thank you for all the replies.
The price arguement is definately striking because it seems that I can only draw the Senn's full potential by upgrading to zu or moon. And hd650 /w cable is simply too expensive, so it'd be either 580/600 + cable or 650 without cable.
I used to have the 580 jubilee (600 equivalent) but at that time I didn' have an amp at all so that doens't really say anything.
Has there been anyone who found the Beyer 880 to be annoyingly bright? (just for reference: I couldn't live with the treble energy on the Sonys but the Grados seem perfectly fine to me. Some peoplec find the Grados to be bright)
Edit: Would the Glimore Lite pair well with the Beyer 880?
Edit: I'd also like to hear the opinion by somebody who really disliked the beyer 880 and why.
Thanks
Originally posted by wallijonn you may want to ask gerG. I say the Dt880 only because of $ and its intimacy with vocals. But chances are very good that the HD650 has better bass. Coming from a Grado you may find the DT880 dark, as you may also find the HD650. Some are sensitive to a certain treble range on the DT880; I am not. I do not find them bright in the least. I find the K501 has better pristine sounding triangles than the DT880, along with better sounding piano high notes. The cloth cover on the DT880 tends to smear the treble a little, giving it a diffused sound; so no, it may not sound very detailed (not brightness). It needs a robust amp. The K501, while having a wide soundstage, does not convey the seamless soundstage transistion (middle channel information) that the DT880 does. I suggest you listen to both. It'll probably come down to $250 vs $450. |
Thanks
