To the extent of my recall, Brown's device would have kept the air in chambers (almost honeycomb-like) while it was being reinforced. The only open end would be the front, which could've been covered with a doped cloth to reduce the ozone emissions to the outside. I don't recall any mention of corona or glow discharges, but it was mentioned that the agitation did often pull air molecules apart. Again, it never made its way to prototype stage (to my knowledge), so who knows how effective it woulda been.
No working model seems to have gone beyond the most standard form of the invention, which looks kinda like Venetian blinds:
Here's Brown himself, demonstrating the device in the '60s, and
here's Adire Audio's prototype from 2006. Though they look similar, the Adire Audio prototype's technology should have a fraction of the power consumption and ozone production at any comparable size.
The technology should scale down to headphone sizes, and so should the reinforced cell variant. I'm not sure how they would compare to a single point-source corona, though.
Either way, I would flippin'
adore the chance to work on a semi-easy HV project. I wouldn't be able to reconstruct the Plasmasonic1 just by looking at it, but probably would be able to follow instructions. $50~$100 for experience and a proof of concept sounds more than great. If you're still considering putting the instructions together, Crowbar, you definitely have some third party interest.
Originally Posted by Carl /img/forum/go_quote.gif
There are: they're big, made of glass, and glow in the dark.
Haw haw. ;p
Tubes existed back in the '80s, of course, but the suckerpunch here is that we want something small enough to fit on the headphones themselves.
This image shows what we're dealing with.
Admittedly, having two functioning 300B tubes sticking off the head would go down in audiophile history... But yeah, we'll stick with solid state for now. I'm just curious to know if there are any solid state transistors which could do the whole 3kV step without affecting the audible frequency response.
Here's the Plasmasonic1's stated frequency response:
Notice how it rolls off at 15kHz, and is really jagged below 50Hz? That's apparently not the fault of the plasma itself!
Check out the three BUX87 transistors:
Notice how if you sum all three of them together, it would keep the frequency flat up to about 15kHz, and create havoc below 50Hz? Booyah. The bottleneck is there.
So the question is, can we find a small modern transistor more effective for our purposes than the BUX87.
