Filburt
- Jun 23, 2005
I tested it first with headphones because, for some reason, it didn't occur to me that it'd have problems. Yes, it was a bit of naiveté on my part...oh well.
Should I order different ferrites? The ones I got are the 50 ohm ones you have in your parts list from Digikey. I don't have any low value SM resistors handy, so I can't test it with those.
I checked the DC offset...it's _gigantic_, assuming I'm testing it right. I used MisterX's instructions, and measured ~1,2v on the right and ~3,9v on the left, which is obviously atrocious levels of offset. This was with the switch just off of the on position (e.g. around the lowest volume position).
While I don't have the spare resistors, I do have the C3 caps. Should I try those?
Edit: Okay, tried C3. Now I get 2,8 on the right and 0,5 on the left...
Originally Posted by tangent Why are you testing first with headphones? I'll bet you find that DC offset is unacceptably high. Yes, that's likely. Can you try some low value resistors (10-100) in place of the L1s? If that fixes it, the ferrites aren't the right sort for the problem you're having. One problem with the ferrite solution is that it requires careful tuning: the ferrite has to match the problem, it's not a guaranteed fix. I'm having second thoughts about recommending it as a default. |
