Filburt
- Jun 23, 2005
Okay, so I've a problem with my PINT. The power supply is 18v (2x9v). I've checked polarity on everything, as well as alignment of the op-amps. I've also checked all the resistor values, and the soldering job is clean.
So the problem is, my ground channel op-amp (AD8397) heats up to burn-my-finger temperature within seconds. Presumably, this isn't normal. So, any ideas on what might be wrong? Is the chip just bad?
I had this problem on the last board, and desoldered the op-amps and mounted it on a new board with fresh parts minus the Alps pot and the rail cap, both of which I tested before using on this board. I have no idea what the problem is, and I'm finding this rather frustrating...
