Originally Posted by mminutel /img/forum/go_quote.gif
There are no OPA132 at digikey anymore so can anyone recommend me another set of chips to try?
-edit- also, the TI rail splitters wont be in until late march so is there another splitter that works well because I would hate to have to spend 2 months waiting.
You could use the DIP version of the TLE and change your layout (or airwire) instead, as DK has tons of these in stock (the TLE2426CP). It's also fairly trivial (and arguably better performing) to build a discrete splitter with a few resistors and an opamp in unity gain, or a dedicated buffer like the BUF634. Likely more expensive in both board space and dollars than using the DIP TLE though. Unfortunately TI seems to be the only company making anything like this IC, I haven't been able to find a comparable chip from anyone else. If you're comfortable with SMD, Tangent is also selling the '
ADAPTLE' which is a small board taking the SO8 TLE and a 1206 capacitor in about the same space and form factor as the TO92 part, and provides slightly better performance.
You probably want to use the OPA2132 as it's a dual-channel opamp so you'll only need one as opposed to two OPA132. Performance should be approximately identical, though with possibly slightly more crosstalk. You could also try the OPA2134 which is very similar but slightly less stable - for most builds this won't be a problem though if you can't source 2132 (and it's considerably cheaper).
--edit-- Sorry, I assume you're looking for an OPAG now that I actually think about what I'm writing. OPA134 will likely work but I'm not too sure. It'd probably be a better watch for OPA2132 in OPAL/R than one of the AD chips. If you can't source it you might want to troll around the forums for reports of people using OPA2134/134 and see how it works in the OPAG position. Otherwise either choose a different opamp entirely for OPAG or change all of them.
Many other chips will work as well, you're likely to have good luck with any FET input unity gain stable opamp. Don't go for anything that has too much bandwidth.
You may want to read Tangent's
OpAmp and
Virtual Ground articles, they provide good information on both topics. Or just go with the recommended parts as they're basically available, if you can handle the small redesign required to use the DIP TLE.
