Emon
- Dec 28, 2003
What's an appropriate voltage for a standard PIMETA (all the standard parts listed on tangent's site, nothing special) with AD843s biased into class A? I did some searching and I've seen people with around 16 or 24 volts. Two 9v batteries in series seems to be appropriate, so I would assume 18v is a pretty good ballpark. What happens if you go higher, like 24 or even 30 volts? I'm not looking at a power supply in that range, but at what point would most opamps and buffers start to fry (I'm assuming all caps are above this level, like 50v). Also, how much current does one need? From what I gather, 0.5 amps should be more than enough.
I'd appreciate some more info...I've been searching but unable to find anything that pertains to my exact situation, and I want to be sure before doing something stupid.
