N@Z
- Jun 29, 2002
Sounds promising, I have the same MD player & Etys as you do. I assume you hooked up the amp jack to the headphone out of the MD player since there is no line out. Personally I am not impressed with the sound direct from the headphone out to the Etys directly (Although I find the HD600 acceptable & obviously Grado SR80 better)
Do post some more impressions after you have done extended listening or after you have run it in longer & using different CDs, like Acoustic Jazz or rock.
Thanks!
Originally posted by FCJ Yes, it did arrive today. Thanks Fixup! I've been listening to the SuperMini for only a couple of hours, using two PCDPs (Sony D-33, Panasonic 470) and a MD that I borrowed on Monday (Sharp 702), all through the Ety 4s. While these may not be the best sources, I think they may be fairly typical of what will be used with the SuperMini. Listening to one CD only (the Daniel Carter Trio "Language) and one Mini-Disk that I copied from a cd I own (Richard Wagner's "Der Fliegende Hollander"), I found the SuperMini to be both dynamic and "punchy." I was surprised in a way to find it as balanced as I did. "Language" contains a lot of bowed acoustic bass that can become strident on some setups. However, the SuperMini handled it and then some. Again, these impressions are based on only a couple of hours of listening, so they may change over time. However, I consider the SuperMini an impressive achievement. It's so small that it will be easy to carry around everywhere. Given additional burn-in, I expect the sound to improve even further. |
Thanks!
