liamstrain
Member of the Trade: The Audio Guild
- Sep 18, 2011
As a for instance (and by no means high-end) the USB on my Yulong D100 - the 24/96 PCM goes through the TE7022L I2S out, then hits the D1896 Async sample rate converter. I cannot imagine higher end models using iso instead of async... but I do not really know.
Data sheet on the TE7022L here - http://www.gfec.com.tw/te7022l
Looks like it's just a pass through to the D1896, which controls the stream: http://www.analog.com/en/audiovideo-products/sample-rate-converters/ad1896/products/product.html
(and the update D200, supports 32/384 PCM and DSD128 via async)
Also regarding errors in high/low frequencies and how they are affected - isn't the number of bits associated with each frequency identical? I don't see how one would be affected more than the other - though possibly one would be more audible... I also thought USB 2 specs required 18ns - 26ns cable lengths to prevent reflections from affecting bit to bit.
