makne
For sound quality, I found that angled leather or pleather pads give the best results. Flat velours (HM5) are not much better than the stock ones imo.
Both leather and pleather are very comfortable, honestly I can't tell much of a difference once they're on my head.
You can fit HM5, ZMF etc. on the rings that are inside the stock pads, but I recommend removing that ring and putting the pads over the cup itself. This way you don't have to stretch the pads so much. The left pad will cover the 3.5mm hole so you'll have to cut a small hole for it or stretch the pad around it, but no major issue really
