Philips Fidelio X1 | Review & Comparison
Oct 16, 2013 at 11:00 PM Post #166 of 373
Hi zazex, based on your opinion, can you briefly compare between K712 and X1? What do you like most about the X1 if compared to K712? Thanks!
I like the bass of the X1's; I like their musical warmth
as contrasted with the still somewhat clinical nature of
the K712's.  I like their slightly larger soundstage - not
as large as the K702's or Q701's, but larger than the
K712's.
The K712's have more clarity, more pinpoint accuracy,
and possibly more treble extension (though this does
not translate into "sparkle" for some reason).
I like also that the X1's can be driven pretty nicely
with a decent portable amp.
Also, it will be a little more time before I can tighten up
this comparison further.  They're both very good headphones
and I need to do a lot more listening to them.
Oct 17, 2013 at 12:03 AM Post #167 of 373
K712's.
Thanks for the comparison! I never listen to the K712 before, but I tried listen to X1 before at a headphone shop. I also like the warm sound of the X1! :-) Somehow I feel that the X1 headband elasticity is a bit tight for me, maybe the headband elasticity will be loosen a bit after some use. Zazex, how to you feel the headband of the K712? If compared to X1, will the headband elastic very tight?
Oct 17, 2013 at 12:29 AM Post #168 of 373
I think they're both very comfortable, but agree that the K712 is a little roomier
with less clamping force.  I would think that the X1 headband will loosen up
over time, but that's speculation at this point.  If it's too tight for you, I'd
recommend against buying it as it may never loosen up sufficiently.
Oct 17, 2013 at 12:55 AM Post #169 of 373
Watch Tyll's video at innerfidelity, where he describes how to loosen it up.
Oct 17, 2013 at 1:00 AM Post #170 of 373
Thanks for your reply!
I am a total beginner in headphones, I am not very sure with audiophile terms.
I have heard that some people mentioned that the X1 sound is a bit distant away, which seems to be less intimate. Can anyone here explain to me, does "less intimate sound" is similar to "recessed sound" ?
Oct 17, 2013 at 5:33 AM Post #172 of 373
Thanks for the suggestion! But my problem is not with the headroom space caused by the arch of the headphone, instead it is the headband elastic (or the so called hammock design mentioned in Philips website) which i feel is a bit tight for me.
I think that's what waynes world was referring to in his post above.
Anyway, it's worth a look if you're considering buying the headphones...
Oct 31, 2013 at 11:20 AM Post #174 of 373
The E10 isn't going to extract any headphones full potential, but it's a nice little device for how cheap and small it is.
Oct 31, 2013 at 1:14 PM Post #177 of 373
Yeah ^
Oct 31, 2013 at 10:11 PM Post #180 of 373
Magni/Modi
O2/ODAC
Fiio E17
I've thought about the Magni/Modi combo, but I don't think I could use my speakers and headphones at the same time like I do with my Fiio e10. Same thing with the O2/ODAC. My friend has a e17, so I will get my hands on those for pairing on my x1 arrives.
  i think the x1's are quite efficient, i think even an iphone can drive it
I want to be able to at least extract more of its potential out of an amp if I'm going to be spending money on the headphones, but it's also nice to know that it could be used with minimal equipment. (:
Would an iPod touch be able to drive it as well as an iPhone though?
Audinst HUD-MX2 is also a good budget dac/amp. Although I never pair them with X1 before, but i think it is worth considering due to its budget price.
Thanks for the suggestion! I will try pairing them if i can get my hands on the HUD-MX2 :p
