PETEREK
Member of the Trade: ThePETEREK on Etsy
Previously known as cCasper TFG
I have a guy handle my powder coating, not paint.
Peterek killed this pair of headphones. Amazing cable and paint job.
@PETEREK First off, I want to commend you on your awesome mods. I was curious what 2.5 MM mount you are using for the detachable cable mod shown above. I have found similar looking mounts with nickel plating and was curious if that's what you are using or if you have found a better source.
By the way this is my first post as a user. Thanks to all those who have built this community into what it is.
The Peterek cable mod was done with extended 2.5mm the Eidolic 2.5 mono plugs. They will work with any HIFIMAN that has the 2.5mm connection!
Looks good, too!
Welcome to Head-Fi!
I think you may be referring to this post from oleWhiskey: http://www.head-fi.org/t/779584/peterek-formerly-ccaspertfg-mod-cable-thread/60#post_12272049, not Mshenay's.
Peterek is awesome! he is actually doing a new pair of X00's for me since I sold those pair and immediately had sellers remorse lol
@oleWhiskey I am curious why you chose the extended over non extended. Simply asthetics?
(facepalm) You are correct. I shouldn't have posted based on a quote on mobile... leads to mistakes like this. @oleWhiskey I am curious why you chose the extended over non extended. Simply asthetics?
to use the cable with the Hifiman he-400i's that has the 2.5mm connection. they are imbedded deeper in the cans so the extended gives me space to wiggle without rubbing up against the frame
