MASantos
- Dec 21, 2004
Well I'm not going to answer your answer but I'll help:
go to TI's website and search for the PCM2702 and the both reg's. Download the datasheet and read it. You should find the current draw of each of the IC's. Be sure to also check the DAC's website to check which other IC's and components draw current with you desired configuration. THe overall current draw should be equal to the sum of all the current draws of different IC's.
One of the most rewarding aspects of DIY is learning this kind of stuff. At least for me and that's what I learned with other DIY headfiers.
Manuel
Originally Posted by doctorkelsey i am SURE this has been discussed but I dont know how to search within a single thread and 30 pages is too much to look through How much current does the alien draw from batteries? thanks a bunch! |
Manuel
