Bxtreme
- Apr 23, 2015
After countless hours of research and perusing Head-Fi, I decided I should probably post my dilemma and get some advice
It seems like there aren't many threads about making a custom surround sound configuration for the PC.
Background
I'm a software developer that uses his computer for programming, listening to music (some of which is bass heavy) and gaming. I am trying to achieve an audio system that is fun to listen to, but has positional accuracy for gaming. This is very important to me.
Currently using a Sound Blaster Omni + Schiit stack + AKG 712 Pro's for serious gaming. This gear provides me with really good positional accuracy and sound stage which is perfect for the games I play (I mostly play action RPG's, FPS's and occasional fighting games).
I also use a Klipsch ProMedia 2.1 system when I don't have my headphones on.
Problem
My only issue with the setup (despite how comfortable people claim the K712's to be) is that I get fidgety when wearing these headphones for too long. I considered getting different pairs to try out, but there are some other considerations. Sometimes I just want to sit down and have some speakers blast. I find myself getting up now an then to do something around the office, but still wanting to hear my current song without having to switch my audio output.
For arcade fighting games,the bass response of a speaker system is just awesome when someone gets slammed against the ground or for the super crazy ultimate attacks!. It's a feeling that is difficult, if not, impossible to emulate on headphone (the thump of the woofer that is).
What I'm thinking
Powered Speaker
At first I researched some powered speakers, Audio engine A5+'s in particular. It will be a little costly, but I could technically set up a 5.1 system with these (obviously picking a separate center and sub). I could hook these up to analogue output on a soundcard. My issue with this is:
1) Each pair of speakers have their own volume control. Seems like a pain to make sure all the speakers are set to the same volume. Maybe one of the gain knobs gets moved accidentally (not sure how) and throws things off until I realize it. That would be annoying!
2) Power cords. Oh the power cords! Just seems ridiculous to have so many separately powered speakers.
3) I heard that some powered speakers (not sure if this happens with A5's being fed with analogue signal) tend to play white noise when no signal is being sent.
Passive Speakers
I kicked around the idea of powered speakers for a while, and then I started thinking about another approach - using passive speakers. Here are my problems with using a receiver to power passive speakers:
A Crazy Idea
This is the current plan I wanted to vet through you guys, unless one of the prior setups makes more sense with some tweaks.
Using an Asus Xonar U7, I can get up to 7.1 surround sound via analogue output. This external soundcard is capable of high fidelity output (192kHz/24-bit on all 7 channels) along with 114dB SNR. I figure using a 5.1 or 7.1 speaker setup, the surround virtualization would be minimal, since each sound channel would have it's own speaker. With the case of 7.1 (if I chose to go that route), the Dolby Home Theater v4 virtualization on the Xonar U7 can mix the audio signal so it is expanded to full 7.1. I would likely turn off all the other processing junk it has. The goal hear is for great sound with just enough processing for great positional audio.
Emotiva Audio A-700 BasX 7-channel Power Amplifier - This bad boy should power most small bookshelf speakers I throw it's way with nice clean amplification. I'll eventually add a raspberry pie to provide a signal to the amp trigger so it can automatically turn on / off when my computer does.
Lastly, I was considering the Wharfedale Diamond 220's (and 220C for center channel). Haven't decided on subwoofer yet.
I really like that I can customize each component in this setup versus having some crappy surround sound PC speakers (like the Logitech and Creative speaker systems).
Questions
FYI - the desk will be custom made, so I'm not too worried about having enough room for bookshelf speakers, unless they are enormous. So feel free to suggest another speaker.
Any advice on the matter would be useful, because honestly I'm shocked that more people aren't talking about this. Once I start building this system, I'll be sure to post the details!
Background
Problem
What I'm thinking
Powered Speaker
Passive Speakers
- I am limited to a 5.1 speaker with optical. If I want 7.1, I would need to do this via hdmi from my graphics card. The issue with this is the passthrough. My new monitor will accept a 4k image resolution at 144hz (using g-sync technology). This currently won't work through a receiver.
- With this setup, I won't have the ability to swap the sound processing unit. The receiver will do the sound processing and signal conversion. A modular setup will allow me to future proof my system, at least a bit longer than joining my video / audio.
A Crazy Idea
Questions
- Are there are obvious issues with this setup?
- Would anyone suggest a better 7.1 external or internal sound card? I know some people like the virtualization on Creative products, but keep in mind that won't matter much with a 7.1 speaker configuration.
- Since the Diamond 220 speakers will be in close proximity to me (between 1.5 and 3 feet), will the setup sound terrible? I realize that near-field speakers are designed in such a way that having them set up close to the listener is not an issue. Since the 220's aren't near-field, I'm worried about the sound.
