There are a lot of analogies to think of, like photoshop:
it's better to take a high-resolution photo for your image editing, because you have more detail to work with, and the small errors that always occur are unnoticeable on the lower resolution result.
In audio, the amount of bits basically comes down to the level of the 'noise floor', 16bit has a noise floor 96dB below the maximum level, 24bit is even higher. If you want to handle effects, volume control etc, the extra bits make sure that any rounding error will be unnoticeable. 24bit remastered is 'good', because any computing errors added in the remastering process (often based on the 16bit CD?) will be well below the detail level that a CD player can provide. (think of the old calculators, where 1/3 * 3 was not always 1!, with 1bit resolution it is 0, with 2bits it's 0.25, with 4bits it is 0.375. ) The more bits the more accurate the signal gets, with the 16bit, those rounding errors occur at 96dB below maximum sound level.
anyway, I'm sort of rambling now, read around and of course: use your Wiki/Google skills.
