luvdunhill
- Mar 22, 2006
Niel:
This was a very informative post! Thanks! I am looking for a Wavetek function/sweep generator and was wondering if anyone could expound on whether or not to go under 4 Mhz? I'm looking at the Wavetek 180 and 188 and have compared them as follows:
Frequency range: 0.004Hz to 4MHz (188)
Frequency range: 0.010Hz to 2MHz (180)
Amplitude: 1V to 10V p-p into 50O (188)
Amplitude: 30mV to 10V p-p into 50O (180)
Wave Forms: sine, square, triangle and TTL pulse. (188)
Wave Forms: sine, square, triangle, ramp, DC and TTL pulse. (180)
Sweep rate: 30ms to 1 min. (nominal) (188)
Sweep rate: 30ms to 20 sec. (nominal) (180)
I'm not too sure what I should be looking for. I tried the software function generation, which is decent, but I couldn't get a square wave worth anything out of my motherboard's sound card
Plus, these guys are cheap and I can wait around until I find a good deal on one! I noticed that amb uses a Wavetek 188, but I was wondering if the 180, which is sometimes cheaper would work just as well!
Thanks!!
Originally Posted by NeilR /img/forum/go_quote.gif As soon as you get your scope you will want a function generator so you have a signal to run through your amp. I ebay'd a 4MHZ Wavetek 182A for about $100. That is a fairly common model. It is a decent basic generator and the square waves look ok up to about 100KHZ or so, which is all we probably care about. The rise is not perfect (a touch of overshoot) but it is good enough for what I need. If anyone is interested I could probably shoot some images and post it. A 4MHZ is probably a good bandwidth for these things. Lesser bandwidths will have more limited decent square wave range and higher bandwidth models get a bit more expensive. Then I ebay'd a lot of twelve 6 foot BNC-BNC cables for $20 or so. I cut them up and make cables as needed. BNC connectors are expensive; I thought that was a decent deal and I have a lifetime supply of pre-crimped connectors. You'll want one BNC-BNC to connect to your scope's trigger; that simplifies the triggering and eliminates constant playing with the trigger level to keep the image stabilized. Another set or sets to connect to your various amp input jacks (3.5mm and/or RCA) and maybe a fallback set with alligator clips or grabber clips. |
Niel:
Thanks!!
