Hello,
I have been using an iFi zen DAC 2 for the past year and it suddenly stopped working. I was using it together with an iFi zen CAN and a pair of hifiman Sundara without any issues.
Recently, the DAC suddenly stopped showing in my Audio devices. The DAC lights are ON though. After trying a bunch of solution I read on different forums which did not work, I have returned the DAC as it was still in waranty and received a replacement but the issue persisted. I know for sure the new DAC it's working, as I said it is brand new and I tried it on another PC and it worked. (plug and play, no additional software required)
Some of the things I have tried so far (in this order):
None of these worked.
Anybody experienced anything similar or has any ideas on how to fix? I have already contacted iFi support and waiting for a reply.
Thank you in advance!
- Trying different ports. I have tried every single USB 3 and USB 2 my PC has. They all work when I connect a different device to them but not the DAC. Weird thing, when I first got the brand new replacement and I plugged it in, it worked for like 10 seconds (got to listen to a song) then it disappeared.
- Made sure I have latest windows 10 updates installed.
- Disable windows power save mode to cut power to USB
- switched to Windows 11
- Uninstall and reinstall USB Controllers drivers
- Used a separate power cord that I had from my ifi zen can amp and plugged it to the DAC
