Parametric EQ Foobar Plugin
Oct 16, 2006 at 9:24 PM Post #16 of 16
Originally Posted by Headphoner
When I name the preset in the box (by double clicking to the left of the U on User) and then export (needing to write the name again in the export box), I can retreive with the name only the first of the curves I exported this way. The other named curves do not appear in the import box, just the first one.
Can you give more detail on using notepad for editing the names?
I think this is the way they wanted it to be --> only one preset can be exported/imported at a time (not all 32 in a bank). This is normal in VST/DX/etc. plugin world. When multiple presets are loaded at once, the file is called a "bank" file then.
I don't understand AIXCoustics programmers logic on this "preset bank"/"preset" matter at all. It either isn't functioning as they have planned or it's not finished yet.
So editing a preset is just to open the "yourbank.e-q" w/ notepad and make those changes you like to do (patch name, other settings).
jiitee
