momoyou
- Jun 29, 2011
It's my first time to review about earbuds.
I like earbuds more than IEMs, because of their sound stage.
I have nine earbuds and IEMs.
For a start, I rank the ones I spent significant amounts of time with thus:
Audiotechnica ATH-CM707 < Starsonic EP-888-E1 < Sennheiser MX560 <Yuin PK3 = Sennheiser MX580 < Criative Aurvana Air =< Ultimate Earssuper fi 4 < Sennheiser IE8
One day, I wanted a new listening environment, and I began to look forearbuds of 50 dollars or less.Then I found PAA-1,and got a contact to Hisoundaudio.
Fortunately, I obtained the PAA-1 Pro for 40$ before it was releasedto to market.
So let me review.
Accessories
Sponge, cord clip, and hard clamshell carrying case. Simple but enough.
Design & Build Quality
The housings used by PAA-1 Pro looks like Sennheiser MX560. Also its design. But because of the difference of material, PAA-1 Pro has feeling of luxury more than MX560.
MX560 is very plasticky and looks cheap. On the other side, PAA-1 Pro has metal parts of its housing same as high-end earbuds.
The cable is Y style, and little harder than MX560. But easy to handle.
The 3.5mm plug gold-plated.
PAA-1 is one of the most luxurious earbuds under 50$.
Sound Quality
Hisoudaudio said that PAA-1 Pro needs to burn in for 200hours at least, and for 1000 hours to evaluate right.
However the earbuds were burned in for only 60 hours, I try to review.
Listening was done straight out of Cowon J3 loaded with 320kbps oggs.
My PAA-1 is burned in for only 60 hours, it sounds very good.
Its sound is very thick, deep and sharp. Especially The acousticpressure of PAA-1 Pro is wonderful. It sounds like speakers put into the ears.
In the earphone that I have, PAA-1 Pro is the nearest PK3. However,the quality of the sound of PAA-1 Pro far surpasses PK3. Hisoudaudio said that PAA-1 Pro is comparable to PK1.I don't have PK1,but I think so.
About the resolution of the sound, PAA-1 Pro is wonderful. Aurvana Air has very good resolution of sound that I can listen sounds that I have never listened before, but its sound is thin that I can't listen well in subways. On the other side, I can easily listen every sound with
PAA-1 Pro in subways because of its thickness of souds.
About sound stage, MX560 is wider than PAA-1 Pro.
However, sound stage of PAA-1 is very confortable. I feel like I'm in a recording stadio or small club. Even in the noisy situation, I can easily listen good sounds because of its sound stage.
Conclusion
If you consider to buy Yuin’s one, I do not recommend it. It is waste of money.
The price of PK3 is 39$. The other side, The price of PAA-1 Pro is 40$.
The quality of the sound of PAA-1 Pro far surpasses PK3.
By the way, I rank again the ones I spent significant amounts of time with thus:
Audiotechnica ATH-CM707 < Starsonic EP-888-E1 < Sennheiser MX560 < Yuin PK3 =Sennheiser MX580 < Criative Aurvana Air =< Ultimate Ears super fi 4 < Sennheiser IE8 < PAA-1 Pro
Hisoudaudio said, “We will be difinitely the stronger competitor in the portable audio field, including the PDA and the earphones market. Time will prove it”.
I think they will achieve in near future.
So let me review.
Accessories
Sound Quality
Conclusion
