Which have a more neutral/balanced sound would you say? Sorry about all the questions!
The Senn in a velty smooth sort of way.
"Velty smooth"? Would the Grados be better for listening to rock then. That's mostly what I listen to. Every kind of rock except heavy metal.
That depends on taste/preferred sound signature.
Grados are very well regarded for the way they present rock and electric blues. However, some find them to be too harsh and/or have comfort issues with them.
The Senn is a great alrounder. It does everything well--except very fast music. There tends to be far fewer "deal breaker" complaints with the Senn. Some prefer its sound signature over Grado for rock.
If you haven't pulled the trigger on those yet, check out the Superlux HD660. Totally forgot about them until jsut now.
They are closed-back though. Open-back headphones have a more realistic sound don't they?
That depends on what your reference is, considering there are open-back headphones that are realistic for certain situations. If dampened well enough they can hold their own.
For example, let's stray a bit out of the budget range. If for example your reference is the tone and dynamic range of the drums if you yourself are playing, with no regard to soundstage, then the SR325 is the most realistic out there. As in you can really hear the cymbals that close to your head. If for example your reference is somewhere in the middle of the audience, then the K550 for example has a slightly more realistic image.
I think I would prefer to be in the audience.
