OT - need help on schematic
Sep 8, 2005 at 3:04 AM Thread Starter Post #1 of 4
Heady
I got this schematic off the net for a adaptor for old flashes to be used on digicams. (Schematic in attachment)
I need clarification on two points:
1. What is ZD1, is it a zener diode?
2. The schematic of the triac has only one lead labelled "G", does it mean it doesn't matter which of the other leads are connected to the "+" and "-" ?
Sorry for being OT, this is my only source of electronic experts. Thanks.
Sep 8, 2005 at 3:19 AM Post #2 of 4
Yes, a 5.6V zener, I believe
2. The schematic of the triac has only one lead labelled "G", does it mean it doesn't matter the which of the other leads are connected to the "+" and "-" ?
Sorry, rusty on triacs and no ref material to look for it, so I'll defer on that one, although I would guess your assumption is correct. You might try to find a suitable triac at digikey, and see if you can snag a datasheet for it... that would probably tell you. And this isn't really that OT... even though you're not likely to spot too many triacs in headphone applications
Revised: Checked digikey and mouser, found a cross-ref at Mouser here. No application diagram, but other terminals are marked A1 and A2. Your schematic wasn't clear on which one goes where.
Sep 8, 2005 at 3:33 AM Post #3 of 4
A triac will conduct in either direction from T1 to T2, but IIRC, there needs be a small current through T1 and the gate to be triggered. Presumably the T1 pins is left of the T2, commonly they're |T1||T2||G| from left to right inline package. As for deciphering the circuit, it's not my forte' but I think T1 should be positive... but I could be wrong, hopefully someone else will verify this. Anyway I think it does matter which way it's oriented but not knowing for certain what the pinout is on yours...
Sep 8, 2005 at 10:27 AM Post #4 of 4
Thanks so much to Pars and Mono. Given me more confidence to tackle this little project, appreciate it. I am hoping to use my flash collection from my film cameras with my digicam.
