Headphile808
- Nov 26, 2008
Originally Posted by Maxvla /img/forum/go_quote.gif They aren't arguing that the data received is not the same, they are arguing that the data is received at different times based on reflections inside the cable. |
Originally Posted by Currawong /img/forum/go_quote.gif The great irony is that when people say that ICs make no difference, they quote scientific tests, but when they say that optical digital cables make no difference, they completely ignore science! |
Originally Posted by majkel /img/forum/go_quote.gif Lack of logical thinking is a general inability of cable non-believers. They think they saw proofs all cables are the same while I have never seen such a proof. This is like that - they saw somebody didn't distinguish cable A from cable B. The conclusion is - X is like Y, D is like C, C is like X, ... any combination is lik A against B. Does it make sense? |
Originally Posted by ashmedai /img/forum/go_quote.gif I believe in logical circles, your first statement is called a gross generalization (when it's not just referred to as silly - "everyone who disagrees with me is an idiot" tends to be shoddy reasoning at the best of times), and the second is called a strawman argument. Am I right? |
]Transfer of digital audio is not a particularly new technolgy. The digital audio stream also contains a great deal of metadata. This metadata includes timing information (embedded word clock) and error correction data. None of this is new, it's been around for more than 20 years and it works! Once the information reaches your DAC or other piece of digital audio equipment it is buffered and the metadata extracted. The internal clock is then synchronised to the word clock data (extracted from the metadata or supplied separately with pro-gear), parity and other error correction is checked before being release in order and in time from the buffer. |
Originally Posted by gregorio /img/forum/go_quote.gif rocker - I am not arguing that different makes of cable don't have different specifications and some have better specifications than others, I take this as a given. What I and several others, are saying is that the very nature of digital audio and why it was invented in the first place makes the specification of the cable irrelevant. Even the very cheapest cable (providing it isn't damaged or faulty) is going to pass a signal well enough so that the DAC can perfectly recreate the original signal. It's black and white, there is no grey, no better or worse, it either works or it doesn't; if it works, it works as well as any other cable. G |
Originally Posted by gregorio /img/forum/go_quote.gif "Bla, bla, bla. False generalization. First - how can you be sure the digital communication between the two devices is flawless?". You can't, transferring any signal is always going to degrade it, at least in this universe. Duh, this is why digital audio was invented!! Digital audio doesn't need to be transferred flawlessly to flawlessly reproduce the original signal, that is why it was invented in the first place! Hello, am I getting through here? It doesn't matter if it's a good quality '1' or a bad quality '0' or if the odd '1 or 0' is missing or out of time, digital systems have been designed for over a quarter of a century to expect and deal with these errors. Without this ability there would be no digital audio! Look, you want to spend $100 on a piece of plastic which is going to make absolutely no difference when compared to a $10 equivalent, you go for it. Share holders are having a hard time at the moment and I'm sure they will appreciate your contribution to keeping them in the lifestyle to which they are accustomed! Cheers, G |
