I have the AKG Q701 and definitely prefer the sound of the Oppo PM3. The bass has more impact and the treble has clarity without being fatiguing. The AKG semi open design does give a sense of room space whereas the PM3 are more intimate. For cool jazz or chamber music I will turn to the AKG but otherwise select the PM3 when it’s time to rock out, swing to big band or immerse in full orchestra. The PM3 are more comfortable and will play louder and with more authority from a smartphone or tablet, although I more often use them with the Oppo HA2 portable DAC Amp.
I also have the Momentum on ear and those have a boost in mid bass and in treble that I’ve learned many folks on this site will call a “fun” tuning. In comparison the PM3 is more sedate. I like that for indoor listening but choose the Momentum for walking about, when the Momentum pop helps move my feet.
In short, if I can have only one, then the PM3. But the fun of this part of the audio hobby is how different HP provide different yet satisfying experiences for less cash than buying different speakers. Enjoy!
Hi, thank you for your answer.
I don't know about the Q701, I have the K701 and these Headphones are the best I've ever heard in my life for alle musical genres. I did the reversible bass mod, look here: https://www.head-fi.org/threads/reversible-akg-k701-bass-mod.660408/
In addition I am using the FiiO A5 AMP. Unfortunately I can't hear them on the go but only at home.
Hi itman,
Don't have the other two headphones you mentioned but have done demos enough to know while good for classical & this is highly subjective & personal, those headphones aren't for me.
The PM3 has no problem with classical or any genre for that matter, just depends on your taste.
Keep in mind, if you want to be technical, which is why it's tricky to compare, Momentum 1 & 701 have dynamic drivers, wheres PM3 are planar magnetic, hence the name.
Main difference being one has a driver which moves as well as vibrates more than the other, think a small speaker driver vs a flat sheet which has less physical movement caused by an electric current &/or signal going through it.
In most cases, Dynamic driver (the small speakers) generally not only need more signal to move &/or vibrate but also takes a bit more to stop.
Whereas, a Planar Magnetic Driver can move & stop with more speed and precision.
This is also where tuning and impedence rating comes in as the latter is defined by how little electric resistance it needs to be efficient. (lower is generally better)
Imagine controlling waterflow through a tap, the more you turn, obviously the more water comes through. This is where volume & audio level comes in by turning the volume knob on your gear to where you can hear comfortably and clearly the details from your source (music, speech, etc) not how necessarily how loud it is.
This is subjective but impedence can be seen as how little you need that tap or knob to turn to enjoy it.
A good way to test equipment & gear to see how good it is, by seeing how low the you can consistently make it to enjoy it without being too loud.
If something is just loud, doesn't mean the detail is always good &/or clear either but that's another topic.
Hope this helps.
Thank you for the information!
I am thinking also about SRH 1540. Did you compare them before you bought the PM3?
