mysticstryk
- Dec 9, 2008
Well, to put it rather succinctly as I am not one for flowery words or purple prose, I found the 1.0's to be a bit more dynamic with a bit better bass quantity and similar treble. The PM-3 does have better subbass and though the PM-3's bass takes a dip at the point of the midbass, it's very well extended, so I wouldn't say it's rolled off any. The PM-3 also overall does better detail (as in real textures and not overemphasized treble) and if you're going exclusively between the two of them, the PM-3 is noticeably faster, as if you never realized that the Momentum's notes just stuck around a smidge too long.
I can't really comment too much on soundstage or imaging. Both aren't anything that I would deem noteworthy but there is good separation with both and no problems with "wall of sound" or the like. Overall, the PM-3 is the technically superior headphone IMO, but the 1.0 sounds a bit more engaging and "fun" due to the increased bass emphasis. I find I prefer the sound of the PM3s when using them for portable purposes as they provide a rather impressive listen without running the risk of fatigue, and they can be EQed very well if in need of excitement on the go. They're both really great headphones though with what I would consider more similarities than differences. The differences they do have are all within a few degrees of eachother if I were to assign any sort of numerical value to their traits.
I'm not really expecting the pm3 to destroy the Momentum. I'm using both for portable use primarily so will be driving them from a Fiio X3ii.
I'll post comparisons when they come in and I've had some time to get used to them.
