Romanee
- May 20, 2004
To clarify: dynamics in music means the range from very soft/quiet to very loud, or from pianissimo to sforzando, or from ppppp to fffff, etc.. To say that Sound Check or any other routine "scales the volume" so that everything plays at the same relative volume means that it compresses the dynamic range, or that the resulting "same volume music" has a very limited dynamic range. It has nothing to do with compression schemes, such as that used in mp3.
Originally Posted by gdg It is indeed just supposed to "scale the volume" and that's how Ipod literature describes it: Setting Songs to Play at the Same Volume Level iTunes can automatically adjust the volume of songs, so they play at the same relative volume level. You can set iPod to use the iTunes volume settings. I would be very annoyed if compression was used because that's a very different process and should be described as such. |
