Shiosai,
has anyone compared the ps audio GCHA with the Opera? |
At your service Sir . . .
I have both and believe them both to be fine, fine amps. The GHCA was actually the first headphone amp I purchased and what drew me to it was the sense of total transparency / lack of colorization (not sure if that's actually a word
). In addition, bass is deep, taut, and well defined.
For the purposes of a more meaningful direct comparison, my comments will reflect these two paired with my W5000's as I believe them to be the most balanced of the cans I own. Please keep in mind that my hours listening to the Opera are only around 30 or so.
Tonal quality - Both exhibit good range, top to bottom, with the Opera seemingly able to extract slightly deeper and more detailed bass. Bass with the GCHA is well controlled nonetheless. In the mids and treble, the Opera comes off smoother sounding as well.
Clarity / Transparency - About the same and it would really depend on the individual listeners' tastes. For my taste, the Opera exhibits a bit more insight into the detail with the GCHA, by comparison, a tad clinical.
Soundstaging - To me, the Opera is a clear winner here as the soundstage seems relatively amorphous (i.e.; open, expansive) with the GHCA being more defined in a more box-like boundry. Not bad, mind you as that box is a big one; rather, it just comes across less natural by comparison.
Build quality - While both really are superb, to me the GHCA's build quality takes the prize. When you get past the flashier style of the Opera, which I rather fancy
btw, the understated and solid look and feel of the GHCA is hard to beat and really grows on you over time. Funny thing is that, although made in America, the GCHA seems more "German tank" to me - think Audi (GHCA) versus BMW (Opera). Again, it's all a matter of taste and what each individual's perception of ultimate quality.
Transient response - Both are top notch and, at this point, it would be for hard to say which one is better. I can see how one might feel that the GCHA would have the edge; however, this might just be more prominent due the fact that the Opera comes off as more balanced over all and does not tend to overemphasize any one characteristic. The GHCA's massive power supply adds to this perception in this area as well as it never seems to sound taxed at any volume. Not sure if that makes sense
, but it's just my gut feel.
DACs - As very little of my listening is PC based using each amps DAC, I do not feel qualified to make a meaningful, well thought out comparison.
Options - (bells, whistles, etc.) Almost forgot this . . . Fairly obvious going to the Opera hands down. Two different impedence slots, crossfeed switch, gain adjustment. pre amp . . . need I say more ??
Summary - Based on the above, my feeling is that the Opera is the better of the two soundwise and with its greater functionality, it seems to work well with a wider variety of cans / sources. Where the GCHA is unabashedly SS, the Opera can fool you in thinking that there are tubes somewhere in the mix - perhaps this is due to the smoother more fluid mid-range. It is definitely a SS amp that tube lovers would likely be very happy with. VFM - the Opera is hard to beat at any price range.
With the above said, in no way am I disappointed with the GCHA which I currently used my Senns 650's (w/ Cardas cabling) most of the time. These two are, IMO, a killer combo, especially with up-tempo and/or Rock music.
Hope you find this helpful.
Cheers,
Garry
