SeEnCreaTive
- Oct 6, 2014
That's the original, should be in post 1 I believeI realize that it's been a while but is there a version where there's a bass screw and hirose connectors?
????That's the original, should be in post 1 I believe
https://www.thingiverse.com/thing:2311438????
The one I'm referencing is the stl that has threaded inserts but only has the bass holes and 3.5mm connectors. I'm pretty sure that post#1 doesn't have threaded inserts...
sorry, I meant the heated inserts that gb160 did. I kinda want to start another one, but even the reinforced one is prone to split with wood pla. I guess I'll just start buying heated inserts and see how it goes
Really good looking cups . I like how you kept one ring red and the other black for 'right/left' as well. Clever!Seems like i some how forgot to post my build. About a year old by now. I really like them but at 550g its quite a strain on the neck during long sessions for me.
Thank you! The pictures really does not do them justice. Its a special color plastic that was used to print them. In sunlight it turs coral green, looks stunning when you have them in hand and turn them towards the light.Really good looking cups . I like how you kept one ring red and the other black for 'right/left' as well. Clever!
I just used Silverstone foam for everything, including the gasket and ear side baffle However it doesn't seem available anymore (well it is, but much more than the $20 I spent on itI'm confused about parts and construction if someone can help me please. I have printed the two part baffles and cups. I still need:
- 2.5mm headphone jacks. Would these work? https://uk.farnell.com/multicomp-pro/mj-165h/socket-2-5mm-jack-2pole-pk2/dp/1267391
- Sound damping foam - Akasa paxmate is mentoned which is 4mm think, it is quite expensive, anyone got a cheaper alternative? Could you use a cheap mousemat for example?
- Some kind of "wool felt" or "closed cell foam" to surround the baffle on the ear side - anyone got a recommendation for this? Can the same material be used as the foam above?
- "Soft closed cell foam" to make a gasket, any recommendations? i don't want to use silicone!
Are those the main parts required apart from earpads and cables? Did I miss anything?
Thanks for any help!
I am also interested in what people used for gasket material. I would assume that it has to compact to be very thin? I probably will be opening and closing several times for tuning so would prefer not to use silicone.OK thanks. I bought the akasa paxmate and will try and use it for everything. Just need the 2.5mm connectors now.
I've used 1.5mm craft foam and 1mm silicone sheet; the silicone sheet is super easy to use, seals well, is reusable, and is easy to cut.I am also interested in what people used for gasket material. I would assume that it has to compact to be very thin? I probably will be opening and closing several times for tuning so would prefer not to use silicone.
