paulmazz
- Sep 29, 2016
How are the vocals with these cups. I've been modding the mk3 with stock cups but I'm having trouble bringing out the vocals. Is anyone having luck?
They often sound like the vocals are behind the instruments. I suspect it's a lack of upper mids.
Here is an image of the build tray that is running currently. It is going to take 36 hours.
https://lh3.googleusercontent.com/-5nIwhhgjzHQ/WKdq-xzMTzI/AAAAAAABgcA/djM2l9cm0yARzEMJ7ktRWT6gxuZSG0WkACLcB/w327-h252-no/AlphaDogs.png
Anyone know how to be able to add photos here rather than having to have links to them?
Does anyone have files that they'd be willing to post that include supports for the flat/overhanging areas? I just ran some test prints in ABS yesterday, and mine were pretty droopy. I don't really have any experience with CAD or I'd make my own. Thanks!
Ffinished my pair today and am so happy with the results.
The connectors are 3.5mm as I already had a couple of 3.5mm home made cables laying around. The connectors are a couple of inline Rean jacks as mentioned earlier in the thread.
The paint is automotive candy red with a whole lot of clear coat layers to bring the shine out. Unfortunately i didn't completely smooth out the cups 100% as I assumed the primer and paint would fill in most of the irregularities. There are a couple of visible striations but It is only noticeable of you are looking for it at the right angles.
I'm really happy with my headband design. It is made up of leather wrapped around the rubber headband and attached with shoe or contact adhesive. A cheap replacement synthetic leather headband from a Logitech headset is stuck on the bottom with double sided tape. Is it probably the most comfortable headphone i own now and looks better than most of the other headband options in my opinion.
Sound-wise they are really good, but still require a small bit of tweaking. I've followed MrSpeakers guide and pictures and am finding the mids a tiny bit recessed and the upper mids a little bit hot.
I feel that this occurs on any headphone when using Alpha Pads. As per the instructions I've added a airtight, bit of foam on the back of the driver, which has toned it down a little, but still required a bit more tweaking.
Does anyone else have a tune they are happy with using alpha pads?
I was using octoprint, which I believe itself uses a modified version of cura. However, I didn't see any options for supports, its' slicer is pretty bare-bones.
