OK ... just finished some in parallel opamp auditioning and I'm depressed and deeply worried that high end opamp swap doesn't make any sense (at least to my ears). Bare with me.
Firstly, let me explain the testing methodology. Intention was to have some controlled test bench. In Bravura case, I've opted to use front/rear/side stereo channels with different opamps and with parallel auditioning. As all those channels are sharing the hardware circuit of same quality (so one is not better then other), in ASIO mixer I can use them as multiple 2 channel stereo tracks. So, as player I have JR Media Centre, output to ReaRoute ASIO, input to Reaper VST host (mixer) and, of course, ReaRoute ASIO Recorder was used as audio stream input. Now, that was multiplexed to 3 Bravura stereo channels (front/read/side) mapped via ASIO to matched analog outputs. ASIO4ALL was used as transport for ASIO duties.
Now, 3 analog stereo channels (font/rear/side) from Bravura were connected via the cables of same quality to audio switch box. Single output from audio switch box was connected to my heavily modified Musical Fidelity X-CAN V2 headphone amp paired with Senn HD600.
Front channel was using AD797ANZ, rear AD797BR and side OPA627AU. So, when playing the audio stream in parallel to all channels (in ASIO mixer), I can switch the analog outputs with different opamps instantly (via switch box) and notice the changes in audio signature. Of course, I deliberately randomised the start-up switch box position so that I'm unaware about the fact which opamp is currently live (blind test). Well, you see, I heard nothing interesting. Nothing. No marked changes in audio signature. All music was in lossless flac format and flavoured from techno to classical pieces
So, what's going on? I believe that testing system was revealing enough, testing was done very late at night (on purpose) so that external noise (or noise floor) is bare minimum, focused auditioning with headphones ...
Previous testing methodology was with my speakers and something like ... audition the opamp, shutdown pc, change the opamp, turn on the pc and audition again. So, there was a pause ... probably just enough for HiFi mental games (placebo and such).
Any takers?
