stv014
- Jul 17, 2011
How do you know it for sure ? Can you prove it in a blind test ? If you just did the typical procedure of listening to the unmodified device first, then swapping the op amps (which takes some time, usually significantly longer than the <1s for which auditory memory is reliable), and then listening again, expecting to hear an improvement, then there is a fairly good chance that you were experiencing placebo.
Op-amps are not a placebo
