Onkyo XDP-30R Replacement Help?
Aug 1, 2021 at 5:46 PM Thread Starter Post #1 of 20
steelgtr
The wifi is pretty much dead and now that I have Tidal, I'd like a wifi DAP to replace it with for around $2-300.
I'd like:
Tidal and Spotify compatible.
Similar or better SQ
Line out
Physical volume control (when not using line out) not deal killer
This is mainly for a channel stereo setup, headphone out not real important.
Thanks for any help.
bob
Aug 6, 2021 at 12:38 PM Post #5 of 20
Thanks for looking that up .My use is in a 2 channel stereo setup, always use 3.5 mm jack, line out mode. Curious if balanced out could be used in this scenario?
Thanks again
bob
Aug 7, 2021 at 1:26 PM Post #6 of 20
Only use the output type that appropriately matches the input type, or you will burn something out of working order. Even if the battery is the power source, the balanced output current is still not grounded, so sending it to a unbalanced input of a plugged-in amp will send an incorrect power charge and probably damage a component, rendering the amp useless.
