ONIX Alpha XI1 - Smallest & Most Affordable ONIX DAC - High-Power Portable USB DAC/AMP
Jul 11, 2024 at 5:27 PM Post #631 of 1,678
Update:
I was using Windows until now, but I finally tested the ONIX Alpha XI1 (4.4mm low gain) with stock OTG Cable on my Samsung Galaxy S10e, using USB Audio Player PRO (bit perfect mode).
Also, a/b tested against my iBasso DC04Pro (4.4mm low gain) with volume matching.
Only used Hifiman Arya planar headphones for testing soundstage and battery consumption.
Battery consumption with screen on at ~25% brightness (volume matched):
-ONIX Alpha XI1: 4.4mm balanced, low gain, nonoversampling, VOL48 or 49 = approx. 6-6.5% drain in 20min.
-iBasso DC04Pro: 4.4mm balanced, low gain, Fast Roll Off, Turbo Mode, VOL53 = approx. 6% drain in 20min.
(I expect less battery consumption with IEMs)
Sound comparison (both used XI's stock OTG cable so as not to introduce extra variables):
Both sound very impressive with the Hifiman Arya.
DC04Pro has sharper/more precise transients, resulting in crisper and sharper percussive sounds that are more elevated in the soundstage while being closer together. XI1 has softer transients, resulting in less sharp but fuller sounds.
DC04Pro has lighter note weight, with sharp attack and less emphasis on the body of the sound. Percussive hits are more elevated and less full, giving a brighter presentation with high percussive hits sounding sharper and more clicky/tappy. The XI1 has a heavier note weight, focusing more on the body and fullness of the sound, with percussive sounds being fuller and more substantial, and high percussive sounds are less clicky/tappy and more natural (this may not be the case if using a dark IEM, in which case the DC04Pro might have better synergy).
DC04Pro and XI1 both have similar dynamic range capabilities. DC04Pro has good dynamic contrast and high percussive hits stand out sharply, whereas XI1's percussive hits are less sharp but maintain a fuller sound. On the other hand, the XI1's dynamic contrast in the bass and mids, with such a full and rich note weight, is satisfying when it occurs.
DC04Pro's bass notes do not reach as low in the soundstage vertically, but the treble is more elevated in the soundstage. XI1's bass notes reach lower in the soundstage and feels where they should be, with treble not as elevated as DC04Pro but at the right place (but dark IEMs might prefer DC04Pro).
XI1 is very noticeably more holographic and atmospheric. DC04Pro sounded flatter and slightly digital in soundstage presentation. XI1 sounds musical while achieving this. While hearing the fuller notes envelope the entire stage, it is more immersive.
XI1 sounds higher fidelity without being artificial/analytical. It is more natural, but I can see DC04Pro being the pick if using darker IEMs.
In terms of treble tonality and overtones, even though DC04Pro has more defined high percussive notes, the XI1 has better timbre and overtones, and cymbal trails have more room between each other (naturally spaced). Timbral differences are slightly more noticeable on the XI1. When a/b'ing, the DC04Pro's sound crisp and defined, but more clustered together, whereas the XI1's sounds more well-spaced in a natural way.
In terms of female vocals' timbral difference, DC04Pro has the edge, whereas XI1's vocals are not necessarily recessed or covered, they are slightly smoother. In terms of vocal forwardness, both had no issues despite the different presentation.
Without a/b, I would be satisfied with both.
If using a dark IEM or one with rolled-off treble, DC04Pro is likely my pick for synergic reasons.
XI1 would be my pick for any IEM that is neither dark nor rolled-off in the treble.
If IEM is well-balanced, I will objectively rank the XI1 higher.
+Sound: First impression was "less edges, more analog- rounded- I mean sounded more like my speakers in a good way. But something felt strange to me. Today I found out what I didn't like (there was also a post from someone who said onyx sounds lifeless. Didn't think lifeless just strange in an uncomfortable way)
...but the bass was there, impactfull and also controlled (I'm sure you can get one with more control for 4 times the price, but control is good) really good seperation and imaging, good soundstage, also voices sounded nice. It sounded "big" and a little more detailed compared to DC04 (has also nice soundstage). And in one or two songs I heard things I didn't notice before. But....like I said in my first post, was not sure if I like it more than Ibassos sound, was like an unwanted hall-effect that wasn't really there...
Sounds similar to what I hear, minus the strangeness. Possibly due to synergy or the XI1 being glitchy?
Also I use the USB Audio Player Pro app (3rd Pic) which has a setting for Bit Perfect audio. That setting bypasses the phone volume & give the cleanest most accurate sound (it also bypasses any eq so if I want to use eq I have to turn off bit perfect). Problem is with the Onix the phones volume still works, which may mean the Onix doesn't allow bit perfect sound through this app. Not sure but when the iBasso is connected the phones volume is bypassed with Bit Perfect on.
Curious what others have experienced when using USB Audio Player Pro with the Onix.
For my experience with the UAPP bit perfect mode, I noticed the phone's volume was disabled when I clicked on my phone's physical volume buttons, but the UAPP hardware volume control was engaged instead (separate from my phone's volume). Note there was one instance where my phone's volume did work despite bit perfect mode being on (I had to reconnect the OTG cable to fix it).
Specifically, there are 3 volumes that I noticed are separate on my phone:
(1) Phone's volume.
(2) UAPP hardware volume control.
(3) XI1 volume and DC04Pro/UAC volume.
When I turn on bit perfect mode for XI1, (1) will not work, but (2) and (3) will work.
When I turn on bit perfect mode for DC04Pro, (1) and (2) will not work, but (3) will work.
So for XI1, I turn the UAPP hardware volume to max and then control via XI1 volume buttons. I don't know if bit perfect mode is working or not, but the sound from the XI1 is good.
I need to crank volume to high 70s into 80 on my Artti T10 planar iems on the 4.4 jack. iBasso definitely has more gain.
My experience in gain is quite different. I used the Hifiman Arya planar headphone which should be more power hungry. In UAPP bit perfect mode (hardware volume at max with XI1) I needed 49 volume on the XI1 to match the DC04Pro at 53 volume to achieve the same decibel level. (Note Turbo Mode was on for DC04Pro.) My experience seems more in line with the specs of the dongles, so something could be amiss.
On Windows 10, my XI1 is also noticeably louder than my DC04Pro.
Another difference in experience is that no matter what headphone I am powering it with, my XI1 barely even gets warm (which is in contrast with some reports here). This is in stark contrast to my previous USB DAC which gets warm just powering my Multiverse Mentor which is easy to drive. I wanted to feel a bit of heat on my XI1 but it would never heat up, not even with the leather case on running nonstop overnight (and we are in the hottest month right now).
Jul 11, 2024 at 8:41 PM Post #632 of 1,678
I had the opportunity to try the Dc07pro and the DC elite side by side with my Onix. Some impressions:
DC07PRO: very clean sounding (in a good way), I suppose it has to do with an amazingly black background. Attack, definition of notes, exceptional midrange clarity, very enjoyable with vocals. Never gets too analytical, never loses musicality, no harshness at all in treble regions. Just clean and clear notes with good note weight. I noticed that the midrange feels slightly forward, and I enjoyed it on vocal tracks. More width than depth in staging, layering of instruments not so 3D compared to the other two.
DC elite: unfortunately I feel I was listening to this on a louder volume than the other two because of the volume wheel notch adjustment. I was in between a setting that was a bit too loud one notch up, and a bit too soft one notch down. So this is not volume matched well, take it with a pinch of salt.
Generally the DC elite, to my ears, improves on the width and especially the depth of staging among the three, as well as solidity of the image. It has thick note weight without losing any clarity, and to me, conveys the best sense of realism and 3D-ness. The timbre leans just a little warmer than the DC07PRO, and I would say that the macro and micro detailing is the best out of the three.
Onix: more depth than width in staging. Compared to the DC07PRO, feels a hair narrower, but better sense of depth and positioning. It also throws a more 3D kind of stage with the depth, which is one of its strengths. Compared to the DC07PRO, the bass has more slam, feels more palpable. The midrange is where I noticed most difference - it is more relaxed and laid back - swapping to this after the DC07PRO left me wanting a bit more midrange clarity and detail. Not that the detail isn't there but because it is less clean sounding, and the way it presents the mids is less in your face, vocal focused tracks are less enjoyable. However, I enjoyed instrumental, city pop, and band centric tracks because I felt immersed in the music making. The Onix also leans warm in timbre, I would place it comparable to the DC elite but I feel the differences are very marginal at this point.
If you can afford to, having both Onix and DC07PRO seems like an ideal state, covering complementary preferences/music
Jul 11, 2024 at 9:13 PM Post #633 of 1,678
Thank you for your comparison. The DC Elite sounds like an in-between option. Can you elaborate on why you recommended XI1+DC07Pro rather than DC Elite?
Regarding the lack of depth in DC07Pro's staging, can you elaborate on how much depth is lacking? For example, certain cables I've tried cause A LOT of depth to go missing. Is that the case with the DC07Pro?
Jul 11, 2024 at 10:29 PM Post #634 of 1,678
Just to be clear, if money is no object, I would just go for DC elite. I'm assuming cost is a barrier here since the DC elite is about double the cost (or more) than the DC07PRO. Also, the DC elite is less portable given that it is a bulkier and heavier unit to carry around despite being a dongle dac. That being said, I think the DC elite would easily be on par with or be a replacement for mid tier daps.
I used the ddhifi TC09s cable, which in my own subjective opinion, I find helps with the expansiveness of staging and perception of detail. I wouldn't say you lose a lot of depth, but it is more noticeable coming from the Onix and DC elite. It just feels less 3D than the other two. If you didn't have the other two to compare, you prob would not feel it is lacking.
Jul 11, 2024 at 11:04 PM Post #635 of 1,678
Did you try lowering the dB by clicking the side button? 0dB, -1dB, -2dB are the steps and will decrease volume rise accordingly.
Jul 12, 2024 at 1:47 AM Post #636 of 1,678
Oh no I didn't know I could do this! Thanks, will try next time!
Jul 12, 2024 at 3:23 AM Post #637 of 1,678
Hi all,
I want to test a theory but I don't have the means to do it, so I will ask for your help.
Can anyone test if the ONIX works on a Samsung phone that doesn't have the 3,5mm audio jack?
My theory is that the phones without audio jack might have some more power going through the USB-C port.
Thanks.
Jul 14, 2024 at 4:50 AM Post #639 of 1,678
Jul 14, 2024 at 8:34 AM Post #642 of 1,678
Jul 14, 2024 at 1:52 PM Post #645 of 1,678
Hi all,
Thanks.
Yes it works and sounds wonderful with Voltage and even more so with Fibae 7 Unlimited.
