HiddenSquid
Does Everyone getting these crackling problem?
The crackling issue is a tough one to nail down.I haven't heard any crackling, it's super clean.
I'm not sure if you meant to say you're going to try the headphones against the DX180 or if you were planning on the Onix...which isn't possible.I just got my XI1 yesterday. Very preliminary testing, but I like it. Only headphone I've used so far is the Meze 109 Pro. They aren't particularly hard to drive, but more so than an IEM would be. I'm using low gain and NOS mode and have volume at about 45 using the 3.5mm output. Works seamlessly on my iPhone and Mac Mini, haven't tested on my DX180 yet, but that wasn't exactly the use case for it. I probably will get the Shanling USB-C to lightning OTG cable so I can use it on my older iPad.
I like that it's a pretty analog presentation. The 109 Pros, and how a lot of people perceive their elevated treble response, don't play well with overly analytical DAC/amps. This dongle is a good pairing with it. I'll put it through it's paces with my other headphones/IEMs throughout the day.
I don't like upscaling in MIDI like that. I use Qobuz and it changes the setting for the song I'm listening to. When I used Apple Music, I had a plugin installed that did the same. Are you saying the Onix won't work with the DX180? I just tried it and it won't automatically detect it, but I've used dongles with the DX180 in the past and it's worked just fine, not sure why this one wouldn't be any different. Generally my DX180 does two things for me: I exclusively stream, so I use it with Qobuz to keep stuff offline for the situations when I need a large selection downloaded for offline listening (flying), and for using PowerAmp for full PEQ. Like I mentioned, my main headphones are the 109 Pros, but I also have the Focal Clear OGs and the Sony XM4s and on both of those I prefer Oratory1990's EQ profile, especially the XM4s, and the DX180 allows me to listen to those with EQ that I can't do with my iPhone/iPad.I'm not sure if you meant to say you're going to try the headphones against the DX180 or if you were planning on the Onix...which isn't possible.
On your Mac Mini... not sure how old it is... but if you have usb-c connectors. Open the MIDI app w the ONIX attached. You'll see it as a device.
If you click on it... you can increase or upscale the output to that device. On my Macbook Pro M1Max, I can upscale the output to the 768Hz/32bit limit of the Onix.
And I'd compare the Onix to the DX180. Honestly the Onix has a slight edge over the DX180 at least IMHO.
I'm house sitting at my sister's and while I brought both the DX180 and the Onix... I haven't broken out the DX180. Its more due to the fact that I'm on my laptop where I use the Onix as an output to my headphones... while the DX180 is when I'm out and about. However... most of the time I'm w my wife so I can't just put the headphones on and tune out. (You don't need to have been married 25yrs to realize its not a good idea.... )
Ok… I never really thought about it…I don't like upscaling in MIDI like that. I use Qobuz and it changes the setting for the song I'm listening to. When I used Apple Music, I had a plugin installed that did the same. Are you saying the Onix won't work with the DX180? I just tried it and it won't automatically detect it, but I've used dongles with the DX180 in the past and it's worked just fine, not sure why this one wouldn't be any different. Generally my DX180 does two things for me: I exclusively stream, so I use it with Qobuz to keep stuff offline for the situations when I need a large selection downloaded for offline listening (flying), and for using PowerAmp for full PEQ. Like I mentioned, my main headphones are the 109 Pros, but I also have the Focal Clear OGs and the Sony XM4s and on both of those I prefer Oratory1990's EQ profile, especially the XM4s, and the DX180 allows me to listen to those with EQ that I can't do with my iPhone/iPad.
I used the iBasso DC Elite with it before with no issues. Not sure why the XI1 isn't being detected. Not a huge issue, since the DX180 does the exact same thing with the same ports and filter options, I just like to know what I can/can't use a device for.Ok… I never really thought about it…
And I don’t have my dx180 in front of me…
The output from the dx180 is 3.5 coax or as 3.5 or 4.4balanced. Headphone/line out.
Input is usb c.
Are you saying you can use the USB-c as output too?
You may need to use a split cable to get power from an external battery if you can use the usb-c as an output….
I’ll have to check that out.
Ok....I used the iBasso DC Elite with it before with no issues. Not sure why the XI1 isn't being detected. Not a huge issue, since the DX180 does the exact same thing with the same ports and filter options, I just like to know what I can/can't use a device for.
Ah, good to know, thanks. I had the CB19 but sold it with my DC Elite. Interesting because the DC Elite theoretically sounded better when using the CB19, but it worked without it just fine.Ok....
Got it to work... Learned something new.
Had to bust my glued USB-C cable to do it though....
The issue is that the DX180 doesn't supply enough power thru the USB-C connection. This is a known problem and why the Alpha doesn't work with certain phones.
You need to use the iBasso cable that is split where you have a USB-A connector for power and then an USB-C for data both going into a USB-C that you plug into the dongle.
This bypasses the DAC of the DX180 and its only a source. You're getting line out. (So you need to make sure the Alpha's controls are set to manage the volume. (I set mine up to do prev/next track. )
So you end up w the DX180 as a music player, and then the dongle is your DAC. Kind of defeats the purpose even though it works.
You said you stream... so its like using your phone and then a dongle dac.
Here's my stack... the alpha, dx180 then my battery.
I'm going to go back and glue up my USB-C 4 cable... I like using it as a headphone jack on my desk.
Not all Samsung phones are created equally. Presumably you're talking about S series?Thats why im using the Alpha and any other dongle like the Elite with a Samsung phone. Samsung delivers all the power a dongle needs and there is absolutely no difference between sound when connected to a PC or Samsung phone.
Yes im talking S series, sorry didnt know they differ in this aspectNot all Samsung phones are created equally. Presumably you're talking about S series?
EDIT: There are reports further back in the thread of some A series not being up to the task..
Yeah. If your music source provides more power... the better the sound from the dongle. People tend to forget that the USB-C is also the dongle's power supply (unless there's a battery in the dongle.Ah, good to know, thanks. I had the CB19 but sold it with my DC Elite. Interesting because the DC Elite theoretically sounded better when using the CB19, but it worked without it just fine.
It definitely defeats the purpose of the DAP, unless you find the sound is significantly better on your dongle DAC and want to still listen to an offline library. Small use case.
