ONIX Alpha XI1 - Smallest & Most Affordable ONIX DAC - High-Power Portable USB DAC/AMP
Dec 26, 2024 at 12:19 AM Post #1,516 of 1,677
I just checked laleeee's battery pack. it is rated at 12 volts 3 amps max so it is a 36 watts power at max and we do not know if that is sustained watts.
If "bass head" means metal or hard rock, then the battery may not be good enough? Maybe more than enough spected from ONIX perspective, but
maybe it only opens up the treble, but then doesn't have enough for the bass?
The spects for the Logilink battery 12V/3A = 36 watts
https://www.tme.com/us/en-us/details/pc-pa0193/rechargeable-batteries/logilink/pa0193-as/
Something like this one probably sounds as bad as the phone 5V/1.5A = 7.5 watts
https://www.tme.eu/en/details/pc-pa0126/rechargeable-batteries/logilink/pa0126-as/
These are way less than the 100 watts I have available.
The max output of the Onix is .5 watts = 4 volts x Y amps
Y = 0.125 amps so these batteries should be more than enough, but... you can certainly hear the difference from 1.5 amps and 2.0 amps.
Dec 26, 2024 at 12:34 AM Post #1,517 of 1,677
That's an interesting perspective.
I think what you did w the power brick (Dell GaN power supply) is interesting.
I tested my macbook's power supply and I couldn't hear a difference between my macbook or the use of a battery.
Of course YMMV depending on the headphone/IEM you're using.
I have to wonder how many test the limits of their DACs by listening to Bach organ music?
Or Wanger Rings Cycle?
Does anyone include this in their test tracks?
There's some good Jazz, but the recordings have some hiss in them...
Dec 26, 2024 at 12:42 AM Post #1,518 of 1,677
I think the point is that not all batteries perform the same just because it is a usb output. Some care should be taken into account to get a battery that is more than enough watts and amps.
Dec 26, 2024 at 3:27 AM Post #1,519 of 1,677
"If you are a "bass head" then you already perfer a more heavily colored sound"
It shows that you don't know what basshead means.
"maybe it only opens up the treble, but then doesn't have enough for the bass?"
This is ridiculous because in the first round you also admitted that the Alpha sounds thinner and brighter to you by using a battery.
By the way, I don't have the powerbank you linked to, everything else is fine 🤣
Dec 26, 2024 at 6:54 AM Post #1,521 of 1,677
Qudelix 5k
Its interesting, but a couple of things...
  • 2.5mm BAL while everyone is moving to 4.4mm
  • BT enabled, which Onix Alpha lacks.
  • Battery (necessary for BT) which Onix Alpha lacks
  • 96kHz vs Onix 768kHz
  • 24bit vs Onix 32bit resolution
  • No Oversampling vs Oversampling also Up Sampling too.(Onix)
  • Requires external App.
  • Built in Mic... No Mic on the Onix
While I noticed this from the Spec... here's a review that covers some of the same.
https://hiendportable.com/qudelix-5k-english-review/
The biggest and only advantage is if you don't want to have a physical connection between your phone and the unit.
I don't know of anyone having compared the two... but I'd say if you're concerned mostly about the sound quality... Alpha has it beat. At least on paper.
The ESS chip can do 384kHz PCM. But the unit is limited to 96kHz? Not sure why unless its a really small and weak battery...
I guess its almost like those BT ear pieces where you can attach your own IEMs.
Dec 26, 2024 at 7:06 AM Post #1,522 of 1,677
Yes thanks I know, my only wish and search is the excellent EQ ability of 5K. As Onix does not offer, so as to be able to EQ while streaming services and not loose the bit-perfect ability, as Peace does not work when bit-perfect Qobuz/Tidal
Dec 26, 2024 at 8:52 AM Post #1,523 of 1,677
Fully agree. BT functionality is great, and the PEQ is amazing- but I personally find that the Onix smokes it for pure sound quality, and enjoyability factor. YMMV
Dec 26, 2024 at 9:18 AM Post #1,525 of 1,677
Well... on my mac, I do have EQMac, however... the sound is still great without it.
Spotify does have some EQ functionality if you go into the settings.
Dec 26, 2024 at 1:06 PM Post #1,527 of 1,677
Hello, what is this noise/crackles you have when using a Mac?
If I have a long listening session w upscale output... there is the occasional noise... I'm still running the initial firmware ... but in this case... its actually the Jazz recordings that have the noise.
I thought Shanling was working w you on the issue you called out?
Dec 31, 2024 at 12:23 AM Post #1,529 of 1,677
@Shanling I thought so too(
Well we're in the Holiday season ...
If they are going to upgrade this... I'd say spend more money on the USB socket. Not sure how to strengthen it, but that would be a good thing to fix.
I agree with your initial assessment back in this thread. But not sure how to show or do a repeatable test.
I mean the pops that you hear are infrequent and doesn't always happen. I'm wondering if its not in the Alpha but could be in the source itself?
I mean I am now running out of available RAM on my macbook pro, and have to routinely kill apps every so often so I have to wonder if the noise starts there?
Also when we're pushing it w more power too.
You and I can't be the only ones hearing this... right?
Dec 31, 2024 at 3:46 AM Post #1,530 of 1,677
I wouldn't say it's impossible to repeat. A completely repeatable addiction. The day before, I hadn't listened to music through Onyx for several days, and yesterday I sat down to listen for a long time, almost an hour - it was perfect, not a single click! But time passed, about an hour, and hello again. That's it, it can't be stopped. The click can be once every 5 minutes, or every 10-20 seconds. It can be barely noticeable against the background of aggressive music, or it can be louder, especially if the sound is declining. This is already random. But the fact that there is interference is natural and always! Now, as before, I power it with a small power bank, which, in my opinion, provides excellent sound. And excellent work with a low-current source, no shutdowns. The power is simply turned on and off by a button. Perfect! Powerbank) Let me remind you that I fastened them together at the end using double-sided tape and glued a magsafe ring - it's incredibly convenient. Now I've added aluminum foil (special from a hardware store on a glue base) to the back side, between the smartphone and the DAC + powerbank. I'm not yet ready to say that there are fewer clicks, they definitely haven't gone away. But perhaps less often. I'm close to solving the mystery and it looks like my initial feelings are being confirmed...
