WyldRage
- Apr 10, 2008
There's a new review for the S4X, and it is pretty positive:
Both look awful.Two problems with that review.
1) He often mentions new drivers on S4X. I don't think Ollo ever stated that the drivers were changed. They look the same and have same specs. Quote from Ollo about upgrading S4 to S4X.
With an upgrade, you get:
So no new drivers.
- New headband
- New earpads
- New inner acoustics
- New individual measurements
- 5yr limited warranty
- We do not return used parts with the exception of ear pads"
2) Comparison to S4 is flawed. He says tuning between S4 and S4X is consistent and difference between the two comes from several small improvements which might be difficult to hear without A/B testing. Thing is the tuning is drastically different between the two. S4 has a lot of emphasis on low midrange followed by a drop bottoming out near 1.5khz. Difference is not subtle in the slightest.
Graph from Ollo's site:
This is my measurement. Not an exact match but differences between the two are similar just the presentation is different.
Keeping in mind SPL doubles for every 6db and perceived loudness is doubled by every 10db the differences here are huge. I'm not saying either of the headphones is bad because of it. They're just very different and the review did a poor job explaining the differences between the two models.
Ok. That got me curious I get that S4 might be harder to appreciate but what is wrong with S4X? For me it's bit too agressive at 2khz and can infact become shouty on a occasion. But overall I would not say it's awfull at all. Quite the opposite considering what other stuff is out there. I added HD650 for reference. That hole in 6-7khz is just something my particular minidsp E.A.R.S likes doing.Both look awful.
Except it's not doing it with the S4.That hole in 6-7khz is just something my particular minidsp E.A.R.S likes doing.
If you run that same test repeatedly are the results consistent ?Minidsp is known to do weird stuff particularly at 5khz and I think that this is something similar. I see this too often for it be an accurate result. There is likely a dip there but it gets attenuated because of the fake ear cavity resonances or because of some other fault in the system. HD650 definately has a dip somewhere between 6khz and 10khz. I say somewhere because looking at all the dozens of measurements available for hd650 the location of the dip seems to be all over the place. Or it is not there at all. Sometimes ringing shows up as a hole in the fr when measured etc. They can't always get this right with $10 000 measuring systems so it is highly propable that $199 ears has ton of weird problems. Peaks in the treble are usually pretty spot on but all dips in the measurements beyond 5khz should be approached with suspicion.
Yes. I think there is something with certain headphones that reacts poorly with the fake ear. I take multiple measurements in different positions for both channels and combine those into one average that should roughly represent the overall sound. Here is one S4X measurement that looks really weird.If you run that same test repeatedly are the results consistent ?
In cases like these, it is wise to use one's ears to determine where there are colorations or frequency aberrations. Or just get a Yamaha HPH-MT8 or HPH-MT220 and see if other headphones sound odd around the 5k to 10k area in comparison.Minidsp is known to do weird stuff particularly at 5khz and I think that this is something similar. I see this too often for it be an accurate result. There is likely a dip there but it gets attenuated because of the fake ear cavity resonances or because of some other fault in the system. HD650 definately has a dip somewhere between 6khz and 10khz. I say somewhere because looking at all the dozens of measurements available for hd650 the location of the dip seems to be all over the place. Or it is not there at all. Sometimes ringing shows up as a hole in the fr when measured etc. They can't always get this right with $10 000 measuring systems so it is highly propable that $199 ears has ton of weird problems. Peaks in the treble are usually pretty spot on but all dips in the measurements beyond 5khz should be approached with suspicion.
Do they leak a lot of sound out the back or are they more semi-open and less prone to that?So, for the Mastering and Mixing process, these could work well, once you learned how to hear them correctly. = Just like every other set you would want to use in a Studio.
Exactly the reason why I've never wrote a review on these here. It's an improvement from original but from "audiophile" perspective I don't think price/sound quality is quite there. On the other hand it has no major sound flaws, great build quality, good warranty & customer service, cheap user replaceable parts and ability perform well on all equipment makes it a solid choice for someone set on buying one headphone and keeping it for 15 years.audiophile approach isn't it for this headphone.
I took my time with my review, did a lot of research, and had a technical approach. The review has been published here:
https://www.head-fi.org/showcase/ollo-s4x-reference-over-the-ear.24473/reviews#item-review-24842
What I have to say is that it I don't think it's fair that in the past people kept referring to Sonarwork's review of the S4 (note: not the S4X!). I did what I could to judge it from a non subjective perspective, this meant studying their approach and reasoning behind measurements. I hope we have more technical review in the future, or at least more reviews from professional audio engineers... because an audiophile approach isn't it for this headphone. I think Ollo Audio did a very good job, it's a serious improvement over their previous models.
