wowser
- Jun 22, 2015
Had these for two weeks now. Started off thinking “These are useless, they’re going back” to now loving them. Think because I’ve got used to the fit (the twist!) and the EQ suggested by this thread (thanks!). Thought the sound cancelling was a bit crap initially, but have started to appreciate it. And after comparing to my friend’s first generation full-size Sony NC over-ears, feel the NC in these isn’t too far off a full sized version (ie, can’t expect miracles). Normally use the IE800 but will switch to these day-to-day. The battery life is really something. And the NC has got me listening to things I wouldn’t normally have the concentration for on the move. Ligeti! Jarrett! Quiet things! Really come round to them. This and the Dragonfly Cobalt have been my favourite discoveries of 2019.
Edit: I’ve also found that using my old Sony ear tips (with the foam insides) has helped with the fit. So glad they’re not like the IE800s with their proprietary design. Anything goes, it seems. Even the Conply that came with my (now deceased) B&O H5s.
