nanaholic
- Sep 2, 2010
There are some features that can be implemented into the OLED screen. For example, you could dimm the screen and after a while turn the screen of the prevent burn in. Or (Lenovo did this with their Laptops couple of years ago with the taskbar) you could move the elements on screen after x -minute of time to prevent burn in. Samsung also does this with their AOD-screens.
OLED is more expensive than LCD and implementing these kinds of features would cost extra R&D. But when you are asking 9000$ for an AMP/DAC. There really should be no excuses of cutting corners.
In the High-end market it's all about little details. When you have LCD that is constantly on, on black screen, you will notice the backlight bleed. (especially in dark room) And when the whole unit is mostly black. It stands out and also make it feel/look less premium.
LCD backlight bleed is not necessarily an issue. The WM1 series has one of the blackest LCD screen I've seen on players with almost no bleeding - even when the entire UI is based on a black background in comparsion to some which uses AMOLED (as some companies just love to boost the colour contrast to make the CD art "pop" on their AMOLED screen - a cheap and known tactic used in TV that shows up instantly when you have a black background). You have to look beyond the base tech and see how the execution actually came out. Just crying "dur LCD not OLED" is a lazy form of criticism.
