Official Request someone who can build headband for RS-1
Jun 13, 2007 at 6:15 PM Post #16 of 32
English is not my first language (i'am French)
Is it a problem or you just misunderstand what i said ?
Originally Posted by laxx /img/forum/go_quote.gif
Why do you keep referring the othe headbands (Beyerdynamic headband in post #1, Sennheiser headband in post #14) as a he?
Jun 13, 2007 at 10:17 PM Post #18 of 32
Well... anybody have experienced of that ?
I'am AFRAID to do this on my RS-1
That's something you're going to have to deal with.
Jun 13, 2007 at 10:27 PM Post #19 of 32
The other option is to try and remove the black rod ends, and then slide the whole headphone cup assemby out that way, but i got no idea how easy it is to remove them.
Jun 13, 2007 at 10:43 PM Post #20 of 32
On all current Grados, the "black rod ends" are just glued in place. They come off with a firm twist. Use a tiny drop of superglue to reattach it.
Even though I have pulled apart the headband on two Grados (MS-1 and SR-60), I would not dare do this on my $700 MS-Pros (nor would I have any reason to do so).
I still don't quite understand exactly what issue you are having with the RS-1 headband. How is it "too long"?
Jun 13, 2007 at 10:45 PM Post #21 of 32
Yes i should precise it here again in this post, the RS-1 headband look Fantastic, but he is Too long
I was not really sure about that (fell the pad was some kinda too low) but since i use Beyerdynamic headband i know for sure Grado headband are too long,
Got me interested,
How is he too long?
what may be your head dimensions?
can you post a picture of them on your head?
Cheers,
Jim.
Jun 13, 2007 at 11:08 PM Post #22 of 32
Originally Posted by *645-k701 /img/forum/go_quote.gif
Got me interested,
How is he too long?
There's about a dozen dirty jokes that can be made about what you said.
Jun 13, 2007 at 11:18 PM Post #23 of 32
Try it with your sr60's, if it works, then transfer the rs-1 drivers onto it.
Jun 14, 2007 at 4:13 PM Post #24 of 32
You comfirm my thought, the solution so is a padded headband who will be coating my RS-1 rather then replace my headband with something like the on model you build
Well it's just that earcup fall too low on my ears, i didn't knew that but look i have a small head (or Grado headphone are made for big head)
So i need a padded headband to rectify this, Beyerdynamic do the job well for This point, but he don't fit RS-1 headband so he look ugly (see pics on the link at begining of this thread)
Jun 14, 2007 at 5:45 PM Post #25 of 32
I think I visualize your problem now. Here is what I would do if I were you (it is drastic)...separate one of the plastic blocks from the metal headband and slide off leather headband as I described in my DIY post. Use a saw to shorten the metal headband. The metal is not that thick so you may even be able to cut it with metal shears. Trim down both ends of the leather headband and reinstall everything. You may have to restitch the threads on the end of the headband.
My DIY headband design can't accomodate padding that is thick enough to make the headphone fit better on your head, so that won't solve your problem. Besides, I am not interested in shipping anything overseas anyways.
Jun 14, 2007 at 6:07 PM Post #26 of 32
You kill me !!
Yesterday you said "Even though I have pulled apart the headband on two Grados (MS-1 and SR-60), I would not dare do this on my $700 MS-Pros" and now you tell me to not only remove the plastic block but to use a saw to shorten the metal headband
Too risky !!!!!!!!!!!
I'll Never do that
Plus the leather headband of RS-1 will be too long in that solution anyway
I think I visualize your problem now. My recommendation is drastic...separate one of the plastic blocks from the metal headband and slide off leather headband as I described in my DIY headband post. Use a saw to shorten the metal headband. Trim down both ends of the leather headband and reinstall everything.
Jun 14, 2007 at 6:25 PM Post #27 of 32
You kill me !!
I'll Never do that
OK then. Since you're obviously not the Do-It-Yourself type, I suggest cutting off the RS-1 headband and removing it completely. You can do this without having to pull anything apart. You can now then attach the Beyer headband directly on the metal headband by itself. You may have to cut a rectangular piece of cardboard in order to have something for the Beyer headband to wrap around.
Jun 14, 2007 at 6:46 PM Post #28 of 32
Will be a crime to cutting off the RS-1 headband
The ony solution i see is a kind of Beyerdynamic headband But compatible with the original headband of RS-1
Jun 14, 2007 at 9:52 PM Post #30 of 32
Lol
Resale ? i'll never sale my RS-1
I just want to find a kinda Beyerdynamic headband but who Fit on RS-1
Originally Posted by wolfen68 /img/forum/go_quote.gif
You definitely don't want to do anything that will hurt your resale value. Maybe it's time to grow more hair or wear a stocking cap like this while you listen:
...and no, that's not me
