00940
- Nov 6, 2002
I indeed solder first and then cut. Because :
- I'm lazy. Long leads are easier to bend, it's faster to cut all the leads at once.
- I'm messy. I often have to desolder stuff because I made mistakes and it's easier to resolder the part somewhere else if it still has longer leads.
- I work a bit in a different way. Compared to your amp layout, I would have run the power supply lines and most of the ground lines on wires, going in straight lines from the PS to each channel. Longer leads are thus needed to solder the wires straight onto the leads of some parts. P2P in my view has the advantage of allowing you to work in 3D rather than flat on the board.
But I sure wish my stuff would look as neat as yours.
Originally Posted by TzeYang /img/forum/go_quote.gif I don’t know why but most of diyers who posted their pcb works don’t solder this way. They would always solder the components first and then trim the leads later. IIRC, Kin0kin solders this way too. |
