baronbeehive
It's still MrCurwens original design but it will be a first trying to get this much power out of this design. That's the reason it's going to be a bigger chassis. To accommodate for larger heat sinks. Gyrator plate loads are great for getting the tubes a flat load line. The downside is that the gyrator FET needs to dissipate as much heat as the tube. If I run the tube at 10W the FET also dissipates 10W, hence big heat sinks =)
Very exciting! A flat load line means zero distortion potentially, that will be interesting to pair that with tube sound, I can't imagine what the end result could be. Could be tube rollers heaven haha!
My APPJ Set amp outputs 3.5W and is one of the trendy low powered SET's so it will be interesting to try to get that extra power out just to see what happens!
