Are there any chargers that will charge 2 - 4 Plainviews at once? |
It's not a trivial thing to make. Either you must charge all of the batteries in series, requiring a high supply voltage, or you must make 2-4 separate chargers because you can't charge NiMHs in parallel safely.
Until someone comes out with such a thing, you might consider DIYing one. The On Semiconductor MC3334
x charge controller I've used in the
PPA battery board is flexible enough that you could use it with the Plainveiws. See that site for plenty of info. It would probably come to about $100 in parts for a 4x parallel charger, including a case and power supply. This charge controller chip can be made to fast charge followed by a maintenance trickle charge, or just trickle charge. It detects when the cells are charged, but it can also turn off the charger after a certain amount of time if something goes wrong.
I'd want to have a phone call with Plainview's engineers before starting the project, but I'm sure it's entirely do-able.
The Plainview charger charges at 25 mA |
Mine measures 27mA, for what that's worth. Since the Plainviews are 170mAh batteries, 8.5 hours should completely charge the batteries.
I hope I've not significantly reduced their life span.... |
I'm not sure how you test that without just charging and discharging them and counting the number of cycles you get.
I use the Plainviews in my META42 and can never get used to the listening to music and the sudden zzzt, music stop when the battery goes dead. |
If that's a v2 META42, you can add two components that make the power LED turn off when the batteries are getting low. This will give you some warning before the battery conks out.
