I should have add this info to the first page (just did): there is an 1.4V DC offset on Fuze line-out. Depends on the kind of amp you used (whether it has a DC filter or not), you can choose to use diyLOD v1 (amp with DC filter) or v2 (amp w/o DC filter).
Originally Posted by Punnisher /img/forum/go_quote.gif Does the Fuze even need coupling capacitors? You'd only need them if you are reading DC voltage from the output. If it does not have DC voltage, you probably don't need coupling capacitors. |
