killeraxemannic
- Jun 14, 2011
Thinking of getting the Ultrasone Hfi 680 or the shure 840's. Which are better?
I understand you perfectly
The E9 amp is much more powerful than E11, which can be understandable given that E11 is just a portable amp, with all the (usual) limitations is has associated. E9 comes with the required cables, which in all truth is just a simple mini-to-mini cable that can be found at very inexpensive prices.
Unfortunately, E11 can't be used while charging, which was actually one of the reasons I steered away from it, after being quite interested. The battery is removable, which is great, but the battery type is not good at all, and I do have quite some experience with that model.
With all that said, while Pro 900s don't need amps to sound good, they do sound great when properly driven. I still say, for now run with your Titanium HD, and once you can, get E9 and be done with audio for quite some time. Oh, and after you get that combo, stop coming here for a while too, it helps to avoid upgraditis
I used to run a Creative card and was also not satisfied. I got one of these and never looked back: http://m-audio.com/products/en_us/Audiophile2496.html
You will obviously need to use a RCA-to-headphone jack cable, but it's definitely worth it. It produces a very clean and detailed, noiseless stereo sound. One of my favorite sound cards.
Anyone know how long the cord that comes with the E9 that goes from the E9 to the sound card in my computer? Hopefully its like 3-4 feet long =/
When I want CMSS-3D for gaming I unplug my DAC and use my trusty Creative X-Fi Xtreme Gamer. Sometimes I'm too lazy to plug in my DAC and listen to some tunes with the X-Fi with it's enhancements and fx off. It sounds fine with my AD700 and it's output is indistinguishable from my Sansa Clip's output. Not great but definitely not worse than my laptop's onboard. You're either having a driver issue or something weird's going on with your settings. Have you tried removing the card, driversweeping the drivers and then reïnstalling? Are your settings in the Windows controlpanel on "stereo" instead of fancy shmancy Dolby stuff? Are you running at 44khz instead of 48khz? This can confuse certain software audio players. Did you try Foobar with ASIO4ALL/WASAPI support?
