I replaced the 24 AWG input signal wire of the GCC-100 amp into 22 AWG Valkyrja and it made it sound worse. I didn't know that optimizing conductors was this important! Then I figured out that the thinner wire was just compensating for a
too fat interconnect. So I modded the Valhalla and tried to hardwire it but it was too stiff and came loose. So I tried my Valkyrja speaker cable without any shielding and it sounded great, but there was background noise that masked detail, I tried wrapping half of it in ERS paper but it still sounded bright, I needed a blacker background.
So I went back to Valhalla and soldered back the Eichmann Bullets using 1 conductor per channel instead of the normal 4. It gave a blacker background and loads of detail. Bass is still great compared to the stock Valhalla, I hear no weaknesses, it sounds better in every way. This is the biggest improvement I have heard.
First impression Valhalla 1 conductor interconnect: Everything is distinct, it sounds like the bass, mids and highs are played back from a separate audio system, it sounds weird. Nothing blends together.
Layering is now very clear. Vocals are smoother and shimmer more. Everything sounds sharper and hairier without being harsh or fatiguing.
The improvement in resolution is the biggest I have ever heard, everything else doesn't even come close!
Replace input signal wires of GCC-100
I wrapped Valhalla power cord with ERS paper but it made it too muddy so I removed it.
I had to do this job twice because amp didn't work. There was a small piece of solder creating a short, lucky that ICEpower amps have short-circuit protection! This job took 18 hours, those pins are crazy small to solder to.
I also replaced the DC wire to the Gain Cell. First I tried 3 conductor Valkyrja (the one on picture) but it was too muddy and bass was emphasized, then I tried 1 conductor and highs were emphasized, 2 conductors is optimal for that DC power.
Valkyrja homemade interconnect
Same wire in and out, why not!
Valhalla interconnect 1 conductor mod
http://poollogics.is-a-geek.net/pict...re.attempt.JPG
Hardwiring Valhalla didn't work, other end inside amp had come loose and no sound came out from either channels. Back to RCA plug.
Now the input (amp) and output wire (K1000) is a single 22 AWG Micro Mono-Filament conductor and there is synergy!
Muddiness is finally gone!
